i only had an ae82 full loom and harness lying around.. a bonus i spose would be that i can plug in a JDM 86 ecu, or run any aussie bigport ecu.. if you had a jdm harness you can only use a jdm ecu.. there is 1 wire different for the injectors..![]()
took the inlet manifold off last night, and dropped it to Ant's, he is helping me alot with getting the little bugs out and i would like take an opportunity to say thanks. he is setting up a 20V tps etc on these for me easy to do, but i don't have testing equipment, he doesget it back this arvo, then i need to find out why my battery isn't charging!! the altenator is outputting 14v!!!
