Results 1 to 10 of 20
Thread: What would cause TPS to play up ?
    kravit
    bowen hills
    Unhappy
    Hey guys,
    I've been trying solve my problem for while now with no luck
    I have replaced TPS,Coils&Igntion, Spark plugs, leads are good, fuel pump
    It would only rev to 4000 revs and just bounce there and miss throttle sometimes, when i unplug TPS the problem is gone but doesnt run the smoothest
    With fuel pump is it ok to have it hooked up to ignition ?
    alex
    wa
    new north
    when you un-plug the TPS, the engine will run in "safe" mode, so this doesnt mean its a prob with the TPS, just a problem...somewhere.
    Mabey its the crank angle sensor? It might be failing at higher RPM's?
    kravit
    bowen hills
    What is Crank angle sensor ??
    Yang
    Salisbury
    So the car only revs to 4,000km and stops?
    Yang
    Salisbury
    If you want a definition of a crank angle sensor, than here is a tech one.
    The crank angle sensor is a basic component of the ECCS It monitors engine speed and piston position, and sends signals to the ECU to control fuel injection, ignition timing and other functions. The crank angle sensor has a rotor plate and a wave-forming circuit. The rotor plate has 360 slits for 1 0 signal and 6 slits for 120 0 signal. Light Emitting Diodes (LED) and photo diodes are built in the wave-forming circuit.
    kravit
    bowen hills
    Where about is crank angle sensor on the car ?
    Well it revs to 4000 and if i play with dizzy rev around 3000,
    When i plug up tps then throttle is not very responsive
    alex
    wa
    new north
    Mabey your dizzy is farked? We could play guessing games all day, just take it to a pro.
    Jul 2009
    go through what you did step buy step..double check everything..does it miss at 4000rpm? or does it stop revving?
    kravit
    bowen hills
    It stops reving, just bounces of it
    Your CAS is in your dizzy
  1. Play in my rack
    By timbo in forum Technical - Questions
    Last Post: 30th June 2012, 07:11 PM
  2. Pinion + crownwheel play
    By hachi_dk in forum Technical - Questions
    Last Post: 24th January 2010, 10:03 PM
  3. Rack play
    By andru_g in forum Technical - Questions
    Last Post: 6th April 2008, 07:19 PM
  4. anybody play runescape?
    By greeneyes in forum Offtopic Discussions
    Last Post: 11th July 2006, 11:02 PM
