Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: What would cause TPS to play up ?
  1. #11
    I've heard of this problem caused by the speed sensor failing, sending the ECU into safe mode (the same as not connecting it on a 20v conversion)
  2. #12
    kravit
    bowen hills
    So what would cause it to go into safe mode, i have tried reseting computer, but no go
  3. #13
    If the problem remains, no amount of re setting of the ECU will help. Sorry dude.
  4. #14
    kravit
    bowen hills
    Seems like electrical then,something not on right or eathed, just cant find it
  5. #15
    alex
    wa
    new north
    What brings you to that conclusion?
  6. #16
    kravit
    bowen hills
    Because when i plug in TPS is fucks up the car, its linked from somewhere along there, i cant see what else it could be after 3 weeks fuckin around
  7. #17
    Jul 2009
    you sure it only happens at 4G or when you get to a certain amount of throttle..cos i had problems with my tps..once it got to 1/4 throttle the car died in the arse..then once you backed off a little it would come back to life..but you could touch the accelerator and rev it to 6g or so with little input..
  8. #18
    Jul 2009
    you sure it's the right TPS switch?
  9. #19
    kravit
    bowen hills
    What you mean by TPS switch ?
    Its correct one, already checked
    But i have noticed when i move dizzy about i get different rev limits but that just retards car i guess because dizzy been messed with
    When i try rev,rev it, it will miss rev, and have ot wait for revs to return to lower rev for it to rev again
  10. #20
    Sep 2005
    My 4AGE is doing it to, more when the engine is cold.
    It is the TPS, where its not making a contact when the throttle is opened and closed.
    You can adjust them with a small screw in the side of it and turn it (Like adjusting a dizzy) move it back untill it idles quite rough then bring it back JUST untill it comes back to normal idling.
    Well I hope that helps, but yeah your not the only one with the problem.
    Peace in the middle east!
  1. Play in my rack
    By timbo in forum Technical - Questions
    Last Post: 30th June 2012, 07:11 PM
  2. Pinion + crownwheel play
    By hachi_dk in forum Technical - Questions
    Last Post: 24th January 2010, 10:03 PM
  3. Rack play
    By andru_g in forum Technical - Questions
    Last Post: 6th April 2008, 07:19 PM
  4. anybody play runescape?
    By greeneyes in forum Offtopic Discussions
    Last Post: 11th July 2006, 11:02 PM
