So what would cause it to go into safe mode, i have tried reseting computer, but no go
I've heard of this problem caused by the speed sensor failing, sending the ECU into safe mode (the same as not connecting it on a 20v conversion)
If the problem remains, no amount of re setting of the ECU will help. Sorry dude.
Seems like electrical then,something not on right or eathed, just cant find it
What brings you to that conclusion?
Because when i plug in TPS is fucks up the car, its linked from somewhere along there, i cant see what else it could be after 3 weeks fuckin around
you sure it only happens at 4G or when you get to a certain amount of throttle..cos i had problems with my tps..once it got to 1/4 throttle the car died in the arse..then once you backed off a little it would come back to life..but you could touch the accelerator and rev it to 6g or so with little input..
you sure it's the right TPS switch?
What you mean by TPS switch ?
Its correct one, already checked
But i have noticed when i move dizzy about i get different rev limits but that just retards car i guess because dizzy been messed with
When i try rev,rev it, it will miss rev, and have ot wait for revs to return to lower rev for it to rev again
My 4AGE is doing it to, more when the engine is cold.
It is the TPS, where its not making a contact when the throttle is opened and closed.
You can adjust them with a small screw in the side of it and turn it (Like adjusting a dizzy) move it back untill it idles quite rough then bring it back JUST untill it comes back to normal idling.
Well I hope that helps, but yeah your not the only one with the problem.
Peace in the middle east!![]()
