yes..after you shave them..
i'm pretty sure that you are going to have to raise the front of your car a bit...
cheers DRFTAE86
i have new bushes with them, u recommend putting them in then shaving it once they are in the arm?
For those that have done the swap, I have noticed the castor rod mounting point is furthur out. This will give the car more castor. Anyone know just how much more?
a wheel alingner should be able to tell you
you dont need to shave off near the ball joint. but at the other end you do.
mmmmm, i though about what u said for a mintue, trying to figure y u wouldn't need to shave off the end near the ball joint (cuz i certainly had too).....
Then it hit me, the reason i shaved it there was cuz it touched the back of the 'brake dust cover', but i realised that at the time i had bigger RA60 brakes, whereas u probly still have the stock AE86 brakes right??
In which case u may not need to shave it at the ball joint end (as u said).
Any 1 else with stock aus 86 brakes that has done the convertion care to add feed back with this issue? Did u shave the area near the ball joint or not?
Cheers.
Ill be able to tell you soon, I could also take pics for a "step by step"
yeh i got stock brakes so thats probly why.
Yeh that makes sence.
How much space do u have between the tip on the arm and the brake dust cover?
Cheers.
not with my car atm, but from memory about a finger width? not sure.
