Results 1 to 10 of 15
Thread: 5 Stud On a Sprinter
    Oldschool Member
    Aug 2005
    Has anyone changed there sprinter to a 5 stud. And how would do it.
    Jul 2009
    Kane
    Coburg
    f*** thats h0t!
    anyway you can buy a bolt on item that bolts to your original 4 stud with 5 studs. ill find a pic
    Oldschool Member
    Dec 2005
    Or the expensive way:
    You could use s14 hubs as per the Toymods article for s13 suspension in the ae86 and use a 5 stud hilux diff.
    Scott
    ACT
    Braddon
    VN/VP commodore rotors fit the RA40 stub axle, if you want to convert to RA40 struts, but the RA40 struts will have adverse effects on front-end geometry (the details of this i am not totally informed of, but it is apparently a bad thing... can anybody elaborate?)
    The other problem is the commodore rotors are very heavy... the weight could be worked around by using billet hubs made for converting VN/VP commodores to VT brakes (they use a rotor hat over the hub), but you're still stuck with the RA40 struts.
    A caliper bracket would also be required for either of these combinations. And then you need to match a diff. All $$$...
    Rob
    Moorabbin
    care to explain why u want 5 stud?
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    yes, as dave said, why?
    Senior Member DRFTAE86's Avatar
    Ronald
    The 86 in the pic is a 4 stud?
    If u wanna knwo about a 86 with a 5 stud convertion look up the post about the raceflo car on ns.com
    Oldschool Member
    Aug 2005
    I want to put some hot silvia wheels on it.
    Jul 2009
    Kane
    Coburg
    i heard that silvia offsets are not suited to sprinters. correct me if im wrong.
    also they are 4 stud anyway. well the older ones are. unless its a new one.
    Veteran slide86's Avatar
    Huw
    Hills
    ohh dear
  1. What is the AE86/sprinter PCD Stud pattern
    By orange in forum Technical - Rims & Tyres
    Last Post: 28th March 2012, 02:44 AM
  2. FS NSW: SSR 15x9s, 17x9s, 4 stud, 5 stud, multis....
    By nebuchernezzer in forum Car Parts For Sale
    Last Post: 8th March 2011, 01:14 PM
  3. 4 stud to 5 stud adaptor
    By dan_9 in forum Perth & WA Events and Discussion
    Last Post: 25th April 2009, 11:06 PM
  4. Stud pattern on a oz-spec sprinter
    By HYPNTK in forum Technical - Questions
    Last Post: 7th September 2006, 07:17 AM
