Results 1 to 10 of 20
Thread: What clutch?
    Alex
    St Lucia
    Im looking for a new clutch for my car. It's a 100kw 4AG (from an AE92). Its had a few mods so it should be a fair bit over 100kw now. Would a standard AE92 clutch be ok or should I go heavier duty? I also want the car to be drivable, so nothing too heavy duty.
    Also the engine is on an old celica T50 gearbox. I think the AE92 clutch is what it needs but if anyone knows differently let me know too.
    Alex
    St Lucia
    Also I found this clutch on ebay.
    Which sounds pretty cheap to me. Ive only asked one other place and they quoted $300 for a clutch, which sounds pretty expensive but still I would expect around $200 for a clutch. Anyone have any thoughts?
    Jul 2009
    if it's on a celica gearbox, you'll have to get a bit of a custom made one.. not sure if an off the shelf will fit.. assuming you have a 200mm flywheel like mine.. you'll need a celica t-50 clutch plate spline to be built with a ae92 clutch combo.. are you in brisbane? i can get one made up for you very easily, good mates with NPC up here.. and can send etc etc..
    it also depends on what sorta driving/racing you do.. drift? circut racing? etc etc.. prolly a 4-5 ceramic pad style (4 or 5 puck there known as) with a spring center, with about 1800-2000lbs clamping pressure would be good, still very very street/car park able.. but bites very nice for clutch kicking in drift.. approx cost is $350 and it will require your flywheel for the optimal setup, as he will grind that flywheel, and setup the clutch on it so you know it will be 100% right..
    matty
    Andrew
    if ur not sure if its a celica or ae92... just pulll it out bring it to ur local repco burson shop... n get them to pull out the clutch boook and match it up
    Jul 2009
    what sorta car is it in? i'm obviously it's a 4AGE..with a celica t-50.. so the celica t-50 box input spline is 1 tooth smaller than the AE86 box..so you have to get a celica clutch disc, and use a 4AGE pressure plate and flywheel.. what you have to research is how big the TA22 celica clutch is (dia) and match it with your flywheel..thats why a custom clutch will be so much easier, as you would have to in a sense buy 2 clutches to make 1.. and even then it will only be a crappy organic disc with a 'heavy duty' pressure plate.. which is usually only 15-20% more than stock.. not worth it if you ask me.. you replace the clutch you improve on it.. then you don't have to pull it out again for ages..
    Alex
    St Lucia
    The cars a 1972 TA22 Celica. I know the pressure plate will be an ae92 and I've read in a thread on toymods
    that the ae92 clutch will fit as well, so I'm reasonably confidant that it'll work. Also theres no identification on the clutch to say what it is, only the pressure plate.
    I'm gonna contact the guy I got the car off to see if he knows, but I'm not that sure that he will either.
    Jul 2009
    all the more reason to do it proply take the clutch out and get a new one setup on the flywheel..
    Alex
    St Lucia
    It does sound like an easy way to go but also expensive. If its just an AE92 clutch kit then its all straight foward and relativly cheap.
    Ian
    NOR
    just go for a heavy duty ae92 pressure plate and then get a brand new clutch plate
    Jul 2009
    still havn't ans the key question.. what is the car going to be used for? is it just a dialy driver? does it get drifted? or raced? this will influence the choice you make greatly.. anyone who puts a full faced standard organic disc into a drifter is going in the wrong direction..
  1. Replies: 1
    Last Post: 19th October 2010, 04:30 PM
  2. altezza beefed up clutch new with clutch disc and carrier bearing
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 15th June 2010, 11:15 PM
  3. Replies: 4
    Last Post: 4th January 2010, 09:42 PM
  4. wtd t50 clutch fork clutch t18 rear bar etc
    By wanabdrifta in forum Cars or Parts Wanted
    Last Post: 13th July 2009, 11:49 AM
  5. Melb: Pedal assembly, hard clutch line and clutch master
    By stahlz_ae86 in forum Car Parts For Sale
    Last Post: 31st March 2009, 07:04 AM
