Results 1 to 10 of 16
Thread: Door Cards
    How do i remove the door cards without breaking my window winders etc.?
    Dec 2005
    pull your window winders off.
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    lol
    Dec 2005
    Cool
    lol i didnt mean to sound liek a smart arse.
    you honestly just pull them off..
    but your inbex and thumb around the round base of the winnder which is attached to the door car.
    now pull towards the opposite door.
    this should come off with very little force.
    GoldCoast
    um neg if you just try to pull them of they wll break, there is a little cercular metal clip that hold them on, that has to be removed first.
    all you gota do is put i screw driver or some shit up there and hope you hit it.
    just look and you will be able to see it and how toget if off.
    Dec 2005
    Mine just pop off.
    Yang
    Salisbury
    And what do you do after that? Do the cards just hold on with xmas tree type clips???
    Dec 2005
    yeah mine were just held on with xmas tree clips.
    which remings me, im going to change my interior to black soon.
    so i might have half my interior up for swap or something
    Jonathan
    You guys are so dodgy, I will never buy a car from you.
    To pull the window winder off, position the winder so its pointing down, get a rag between the winder and the door trim, pull up on either side of the rag. This should free the metal clip, then see if fly across the workshop!
    Or some workshops have a special tool, a flat bit of thin metal made like a fork to get the clip out.
    Then make sure you get the philips screw in the door latch(may have to remove latch also), the big screws in the arm rest (behind the plugs)and anything else before you pull the whole door trim off.
    thanks 4 that fellas very helpful
  1. Ke70 Door Cards!
    By chrisfindlay in forum Cars or Parts Wanted
    Last Post: 1st December 2011, 12:24 PM
  2. custom door cards
    By MR86ER in forum General Topics (No Technical Questions)
    Last Post: 28th January 2011, 06:52 PM
  3. JDM door cards
    By McLeod63 in forum Cars or Parts Wanted
    Last Post: 16th May 2010, 09:00 PM
  4. door cards
    Last Post: 28th January 2010, 09:24 PM
  5. JDM door Cards
    By stinger_007 in forum Cars or Parts Wanted
    Last Post: 9th July 2007, 06:07 PM
