Results 1 to 9 of 9
Thread: highbeam problems
    Hey all,
    I recently found that I have a slight problem with my car. Today some guy cut infront of me in the middle of the night. So instead of beeping him/ her I flashed him/her and my lights totally blacked out ( like driving with no lights) but my headlights came back after i took it of high beam. Is there a way I could fix this myself? I have no clue what the problem could be..
    Thanks
    "Impossible is not a declaration, it's a dare..."
    Yang
    Salisbury
    You could possibly even blowen both bulbs. Have you checked?
    Veteran Wally's Avatar
    my lights last night turned off by its self... thought i hit the high beams and they worked again
    4AGE 16V
    ... loose wiring perhaps? ...
    Rob
    Moorabbin
    I had this problem with my last sprinter. I would turn on the highbeams and the lights would go out completely, after a short while the highbeams would come on properly. The time that they came on after varied a fair bit and often they would come on instantly so it was a bit like playing headlight russian rulette or something
    I didn't ever find out what the problem was but its common for sprinters to have problems with the pcb in the headlight switch.
    Yang
    Salisbury
    I never heard of it. It's bad enough with the dash lights going out but the high beams aswell
    Rob
    Moorabbin
    Oh yeah, also changing the lightbulbs did nothing for me so I dont think that the problem was there.
    Hey guys thanks for the replies,
    It is definately not the bulb as the lights work as they should bar the high beams. Does anyone else know what might be the problem? Could it be a fuse?
    I have no dash lights... lol... been like that for a couple of months now
    4AGE 16V
  1. Overheating problems
    By Stej in forum Technical - Questions
    Last Post: 10th November 2010, 07:13 AM
  2. Highbeam indicator not working
    By dtour in forum Technical - Questions
    Last Post: 17th June 2010, 04:18 PM
  3. problems
    By wide s13 in forum Technical - Questions
    Last Post: 24th May 2008, 11:48 AM
  4. problems
    By slidekid in forum Technical - Questions
    Last Post: 23rd May 2008, 04:06 PM
  5. More problems
    By LordNafe in forum Technical - Questions
    Last Post: 17th August 2007, 09:55 PM
