Don't use RA60 struts... They are designed for more KPI than the sprinter has resulting in positive camber. If you use the sigma control arms you may get off with -1 or 0 camber (I'm not too sure about this exactly though as I have never seen the result of these struts with sigma lca).
RA40 struts will result in better geometry with all the sprinter gear, they are good also because they have the larger stub axle (as does the RA60) that you can put decent brakes on (like supra).
If you choose to go either they will both bolt to your stock steering arm, you will need to run sprinter strut tops also.
I hope that this helps...
