Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Diffs
  1. #21
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    correct, it will not last forever, nothing will once u treble the horsepower, if your spending the money on a turbo'd engine then spend it on the rest of the driveline aswell
  2. #22
    Rob
    Moorabbin
    Hey these are the spider gears not the crown wheel (the crown wheel is the bigun bolted to the diff casing)
    What your mate has done there is essentially made himself a detroit locker, I don't know how common that is in the 4wd scene but I have never seen it like that before, looks pretty cool.
    What it will do is differentiate for a very little bit before it locks up totally. I'm not too sure if that would be so good for the drifting crowd as on bitumen it would be really clunky and the impact loading on all the other components in the driveline might make things like axles break quicker.
  3. #23
    its simple to just go with a weldie setup just pull out the centre and poke a welder in the little holes where the spider gears are.
  4. #24
    Senior Member Brenton 86's Avatar
    Brenton
    Hey guys,
    Iv started the mission to lock my s-series, its starting to give me the shits as i have little tech knowlegde, so far iv:
    1. pulled the rear diff/axles completly out of the car
    2. removed the drum caps and pads.
    3. undone the bolts on the front face of the diff
    Now i understand ill need to pull out the axles to removed the center of the diff, so i undid the four 14mm bolts on the plate around the axle under where the pads where but now the whole drum is free and i still cant pull the axles out,
    Question time, is there anything else that fixes the axle or is it just old and tough to pull out?
    thanks
    ADM 4AGZE SPRINTER
    JDM SR20DET TRUENO COUPE
    ae86s love since 2004
  5. #25
    Veteran biggo's Avatar
    Nick
    Noosa
    thatd be the old and tough axle pull out hmm. Bet they havent been removed befor?
    Anyway, just reverse the drums and use that as a crude lide hammer on the wheel studs. Should come free after a bit of a workout
    Oh yair, make sure youve drained it
  6. #26
    Brenton
    Thanks mate it was accutaly an broken axle bearing that had jammed it up.
    s-series are the gay shit to lock, mine only lasted 5 corners and i totally welded the top removable spider gear to the crown wheel. And all the welds have to be grinded up flush or the casing bracket wont sit back flat. Hardest centre to weld up ever.
    Everyone at the workshop it 100% baffled at how it could of broken it was the cleanest job, Will pull it back apart on Monday an give a full diagnoses. I also have another s-series centre so will be learning from our mistakes an ill post the best way to lock it up.
    ADM 4AGZE SPRINTER
  7. #27
    Senior Member darkon's Avatar
    Shawn
    ACT
    Canberra
    apparently these dudes'll send ya a nice kaaz one for $950
  1. diffs???
    By MR86ER in forum Technical - Questions
    Last Post: 24th June 2010, 10:12 AM
  2. diffs
    By rolla92 in forum Technical - Questions
    Last Post: 25th April 2009, 05:28 PM
  3. Diffs?
    By jamekins in forum The Drift Channel
    Last Post: 2nd January 2009, 10:33 AM
  4. diffs diffs diffs
    By ae71 drifter in forum Technical - Questions
    Last Post: 21st September 2007, 01:46 PM
