Results 1 to 7 of 7
Thread: after market seats
    Senior Member xsoarerx's Avatar
    Logan City
    jsut wondering if anyones got thoese after market seats similar to the ones jus jap are selling, bride nock offs?
    my question is, with putting the seats in to a sprinter can you use the orginal seat rails that bolt in to the floor and the seat slides on and put the other seat in on top of them in stead of having to much around with making the new rails compatible?
    they seam similar but im not totally sure it will work or if its safe to do so?
    Alex
    St Lucia
    I tried swapping rails once and it didn't work out and I couldnt get them back onto the seats but that might have just been those seats.
    Also how much are just the rails? I always thought they were pretty expesive.
    Logan City
    im not sure, thye came on the new seats... i might give them a try, if it works it beats drilling holes and stuffing around
    Oldschool Member
    Jun 2005
    Hey man
    Yeah u can use your existing seat rails .... i wouldlove to explain but its way to hard and plus i cant be fukced.
    Ill post some pics up all u need is a welder and some time
    Leandro
    Logan City
    well i got both of them... i'd love to see them when you get around to it
    You can drill grind chop the original seat base off and fit a aftermarket, but most seats end up too high imo. Even a bride on a bride rail is higher than a oem seat. I've got a obx daytona, and it has too much underthigh padding, giving a knees up seating position. Would be better if I made some custom lower mounts, but i'd probably lose the slider in the process.
    Oldschool Member
    Jun 2005
    Your right on the money
    Your seat will sit higher alot higher and if ur tall u better hope u have a recliner
    I've seen Josh Youngs (mr2drift) seat rails and he mad them super low but yes u do lose the slyder which means u have to get a mod plate for a 2 seater and then u have to register it as a 2 seater so yeah sorta sucks wang both ways
    Leandro
  1. Replies: 26
    Last Post: 23rd November 2010, 05:40 PM
  2. after market computer
    By ae86ln in forum Technical - Questions
    Last Post: 11th August 2009, 09:34 AM
  3. Installing after market seats
    By vivioman in forum Perth & WA Events and Discussion
    Last Post: 25th March 2009, 10:56 PM
  4. after market computers?
    By 5PRNTA in forum Technical - Questions
    Last Post: 28th March 2007, 07:51 PM
