Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 46
Thread: car body strength
  1. #21
    stefan
    vic
    eastern suburbs
    how about arch welding? iit hasnt been mentioned, is that because its shit?
  2. #22
    Jul 2009
    Kane
    Coburg
    im not saying im goin to do either yet. jus want to get other peoples thoughts!
  3. #23
    Johno
    Bankstown
    I presume you mean arc welding or stick welding.
    Arc welding can or will burn holes and warp the metal as the metal's too thin. Fine welding your diff and all that, not the best for the chassis. You can get away with it, you just got to be really good.
  4. #24
    Jason
    Gold Coast
    ok so its been mentioned not to rivet on tension points, where exactly are the tension points on an 86, cos riveting seems so much easier for me,
  5. #25
    Jul 2009
    Kane
    Coburg
    ok. ive done a shitload of research! and what i have found out is that
    riviting is just as good as welding if you do it right!
    but if i was to pop rivit and do it right i would have to buy stainless steel rivits, and put them in with an air rivit gun. prime the holes etc.
    welding. all you gotta do is grind back the paint where welding, stitch it up, then paint over.
    i think it would be cheaper to do it by welding. so i think that is what im goin to do.
    much appreciated for all your comments!
  6. #26
    Jason
    Gold Coast
    but from what i have been told hibinos car along with many other jap drifters is just done with your standard cordless drill a pile of normal rivites and a basic rivit gun,
    they have been doin the shit for a while im guessing there pretty on to it.
  7. #27
    Sep 2005
    You forgot to mention that, in case of an accident rivets are easier to remove than mig welds.
  8. #28
    Jul 2009
    Kane
    Coburg
    ae86 slide- the aluminium rivits are not very strong and can work themselves loose. so i would rather do it the right way.(if i was goin to rivit)
    dorio- not really, as stainless rivits are farken strong. you would need a good pulling tool or good drill bits, as for wleds all you need to do is grind them back.
  9. #29
    Sep 2005
    There are two ways, with a chisel or a drill bit, all you have to do is knock the head of the rivet off and it's loose.
    With a spot weld you have a: grind it
    b: drill it (its harder than what it sound)
  10. #30
    Joel
    Blackwood
    Dont drill anything...weld it!
    Steve-AE86 is an awsome welder. He's helped me with mine.
    He used to work as a professional mig welder. He's also a qualified Toyota mechanic and knows sooooo much about hachis.
    AE86 4AGE "Slowly but surely"
  1. WTD: Pic of hole that window/mirror wiring runs into the body of car
    By oz_eight6 in forum Technical - Questions
    Last Post: 7th September 2012, 06:03 PM
  2. Replies: 0
    Last Post: 4th January 2011, 03:50 PM
  3. NEED HELP Sunroof, Strength question
    By damo46 in forum Technical - Questions
    Last Post: 28th March 2008, 10:58 PM
  4. Chassis strength with stiff susp
    By doridori in forum General Topics (No Technical Questions)
    Last Post: 3rd June 2007, 01:23 PM
