Results 1 to 10 of 10
Thread: konig unkowns on a 86
    stefan
    vic
    eastern suburbs
    hi all,
    i have asked this question on 3 forums and never got a straight answer.
    what do i have to mod on a 86 to get konig unknowns on 17x7 or 7.5 (cant quite remember) obviously the car will be needing to be converted to 5 stud.
    any help would be appreciated
    cheers,
    stefan
    Johno
    Bankstown
    are you asking what is needed to get the car to a 5 stud?
    other than that all i can see that might be in your way is the clearance of your guards and maybe it'll hit your shocks.
    Joel
    Blackwood
    Oh god :s
    You'll have to do some significant mods/upgrades to get the car from 4 stud to 5 stud. This will cost you crap loads of cash.
    Depending on the offset of the wheels, you may need to roll or flare your guards.
    On another note, 17's on a hachi will 1. look ghey, 2. decrease the cars handling.
    My advice: GET NEW WHEELS!
    AE86 4AGE "Slowly but surely"
    Poh
    Bevo
    i've seen racers use 17inch wheels on the n2 cup in japan its strange though
    does different size wheels really make a difference eg 14's being better than say 16's, plz explain
    Andrew
    arent 86s suppose to be a budget drifter?
    just get 14s... tyres are cheaper than 17s
    stefan
    vic
    eastern suburbs
    thnx for the replys guys, i was just asking to get an idea as i asked on other forums and never got the correct answer.
    cheers,
    stefan
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    the bigger the rim the smaller the tyre wall therefore less movement under force, so the bigger the sidewalls the weaker they r (i think its called side-flex?? unsure) also the bigger the rim the heaver the mag is so some times the feel of the car becomes different. thats why people put smaller width tyres on wider rims to help stretch out the side wall to reduce flexing.
    also
    a mate with a s14 put 17" or bigger (chromies) on his car, and the car felt sluggish (acceleration) when compared to the stock wheels because im guessing the were a heavier tyre package and had more grip, so therefore reducing the ammount of slip during take off. if im worng plz correct me
    GoldCoast
    i think he needs slightly bigger tires, too much strech
    Joel
    Blackwood
    Sure! that looks hot!
    A mate of mine has wheels that look like that. He stretched i think some 205 or 215/45/17s on a 9.5" wide rim.
    Using bigger diameter wheels also changes the overall rolling diameter.
    Eg. running 195/50 tyres on a 15" rim has a smaller diameter than 215/45 tyres on a 17" rim.
    If you have some 15s and 16s with decent profile tyres, try them both on your hachi...you will find that the 15s are better
  1. Konig Appeal F/S
    By DannyBoi in forum Car Parts For Sale
    Last Post: 18th November 2007, 01:28 AM
  2. Konig rewinds
    By Grantobius in forum General Topics (No Technical Questions)
    Last Post: 8th November 2006, 06:39 PM
