If you were to use short stroke front shocks/insert, the way I understand it is that you should cut the strut and use a small spacer to get the proper bound/rebound. The question I want answered is - is there an easy place to cut?
What I understand is you shouldn't cut from the top because you need the threaded section, and if you go to the trouble of cutting the middle and welding it back together you might as well weld on a coilover sleeve kit at the same time.
Or am I just on the wrong track??
