got a pic?
is a red top as in the twin cam 16 valve on the cam cover is red letters a small port 100kw motor and what other signs should i look for any info would be good thanks
got a pic?
a dead give away is the intake will have a badge "tvis" which is bigport and the sparkplug leads
yeh i tried to put a pick up but it seems it didnt work. yeh its more like the bottom pick except the whole head isnt red just the twin cam writting the sparl plug leads look like the come from the same spot thanks alot for the help
Sounds like a small port. How many ribs does the block have? 3 or 7? Is the inlet long and have T-VIS on top of it?
r tha big ports map sensored ?
re map sensor.. most big ports are. some aussie ones out of ae82s and some mr2 ones arent.
small ports have a breather/drain at the back of the intake side cam box. its a rubber hose that goes down from the head to the block.
obviously if its tvis it big port.
some big ports are 7 rib. the breather pipe is the best way to tell. youre question is is it big port or small port. not is it gen 1/ gen 2 bottom end. the breather is specific to the small port head casting.
78's
