I'm pretty sure the safest is 82mm to keep a safe distance between the water jackets and oil galleries...
I could be wrong![]()
Like the title says I am considering in boring my 7-rib 4age engine out.
What would be the safest tolerence to bore to?
Thanks
Previous cars:
BMW 318i, Mazda MX5, Mazda Familia, Toyota Levin GTV (miss it), AE71, AE92 corolla x 2, Honda Integra Type R DC2 (awesome car),
Mitsubishi Evo 8 MR (Missing it)
Current Car:
2013 Hilux SR5 (turning it into a off-road warrior)
I am looking for a track only car..... Thinking of an AE86 to use.
Cool, That is all that I wanted to bring it out to.
Previous cars:
Current Car:
You will get to 83mm but its does get a bit thin between 2 & 3
Chris O
Toda do some very sexual pistons for the AE111...
82mm
11.8:1 Comp!!!
OMGWTFBBQ!!!!!!1111111
I would only bore out the minimum required to re-hone the bores. If you're trying to gain extra engine capacity by overboring it's probably not the best way to go about it. You'll gain a tiny fraction for a substancial loss in block strength.
Eddie.
actually when i meantioned that boring weakened blocks on boostecruising i got abused (alot) bye people saying that it made the block strongersomething about sleeves?
if you use sleeves then yes it can be stronger. but 4ag's are a close deck design so it wouldnt add alot and i dont think youd ever need it.
anyway 82mm is the max factory recomendation/size they supply pistons up to.
83 is done sometimes but its not recomended for the reason mentioned already.
if you actually saw how thin it would be if bored that far you wouldnt do it.
78's
Yeah. Thanks fellas, I think I just get them cleaned up instead of going in and trying to gain extra capacity. I will focus on balancing more.
Previous cars:
Current Car:
Good idea. Money better spent on balancing then trying to chase .80 capacity increase and only 2hp, if that. Justa guess but you get the idea.
Steve
Insert witty comment here....
