You know I never got the point of banning someone, specially for stupid reasons such has you guys not wanting to understand me.
Let me be more clear, it started with lattice engine, (the reason for this was it's a cheaper engine then the starion, also I wouldn't have problems using the starion gearbox (a gallant or an evo engine, these gearboxes cannot be used).
Then the engine went pop, so instead of rebuilding the lattice, used the gallant block with the lattice crank(2.4), wiseco pistons(had to re-bore the block, nice and tight), now with this set up I could use the vr4 twin cam head with some new valve and valve stiffer rings with cam gears.
I never said I had an evo or 3sgte engine, but they do weigh similar, but mine is heavier![]()
The 3sgte is not heavier than a 4gsomething something, your just pissed off because your not having it your way, maybe I'm not good for business or maybe your to hard headed, I don't care.
You cannot force people to believe you by banning me without a real reason, and I'm pretty sure if there wasn't a reason you would be quick to make something up.
You're pathetic.
