Results 1 to 10 of 11
Thread: ra60 diff will it work
    Oldschool Member
    Aug 2005
    i've been offered a ra60 the question will it fit and will a kaaz lsd center go in it???????
    Oldschool Member
    Mar 2005
    mike
    qld
    goldy
    think so... just need to weld some brackets on for you arm thingos
    Ahhh dont the RA60's have the G series diff?
    Or is that the MA60's
    If it has a T series then yes, just make sure your center is to suit the Zenki model
    Oldschool Member
    Mar 2005
    mike
    qld
    goldy
    ra60's have a t series, yeh just make sure its a 23spline axel
    Unless you've done it, or seen someone bolt one in, don't say maybe, because telling lies is bad.
    It's definately different for all the mounts, definately a t series.
    you could push it and bolt it in using the mounts on the ra60, but it's not proper.
    dan
    Oldschool Member
    Aug 2005
    great thanks guys for the info... i'm not shore if its a t series or not but i'll find out .. once again thanks for the help...
    Veteran verm69's Avatar
    Dave
    Gold Coast
    I'm 99.9% sure RA60 are T series
    -=Back by popular demand=-
    Oldschool Member
    Mar 2005
    mike
    qld
    goldy
    Ok then yes they will work and yes they are a T series and yes you do have to change some brackets. Most ive seen have been 4.1 ratio
    Eddie
    Yes it will fit. It will widen the track by around 15mm and you'll need to re-position the sway bar and panhard rod mounts. Trailing arm positions are apparently identical. It's definately a T-series and has drum brakes. It's probably much easier to find a T-18 diff instead seeing as these will bolt in without mods and you can use the tailshaft for it as well. I think the RA60 diff carrier is slightly shorter than a T-series ae86 or t18 so a custom tailshaft will also be needed.
    Eddie.
    I have an RA60 diff and was going to put it in my AE86. I was going to have to move the Upper Lateral Arms 30mm in or out to get the correct positioning. I didnt really measure anything to do with the Swaybar but yes, it gives you more track, and for me, having to play around to have the tyres at a nuetral setting, im starting to think ill just get a t18 rear end, even though the RA60 one cost me $0 and my T18 tailshaft cost me $0 to bolt up.
    For now im just going to grab my previous locker from my S series, and have the bearings and seals replaced with something better. When using the S series with a locker my centre bearings always start making noise after awhile. Not just daily driving, it sees the track atleast once a month.
  1. ra60 diff info please.
    By Jacobxxx in forum Technical - Questions
    Last Post: 10th January 2013, 11:10 AM
  2. ra60 diff t series???
    By stealth86 in forum Technical - Questions
    Last Post: 30th September 2012, 09:31 AM
  3. RA60 rack ends work with 86 LCAs
    By ke70dave in forum Technical - Questions
    Last Post: 26th May 2010, 04:04 PM
  4. ra60 diff problems.
    By bdske in forum Technical - Questions
    Last Post: 14th March 2010, 09:38 PM
