Location?
im after someone to tune my car i played with tps and now when rev up and take foot of it stalls its gay and throttle is on or off you cant gradually put foot down. I heard of a company called crosley i think in the city are any good btw car has stock computer running 9psi sc14
Are you trying to tune a toyota ECU or other??
Sprinter Veteran
standard ae101 computer its not runing right after putting sc 14 in and I played with the tps
Yeah, didn't use to be, something must be up with their server or something.
- You can e-mail them on that address
You will need to set the throttle back to the standard position as this is required for correct Idle.
How are you controlling the SC14 is it on all the time? if it is the standard computer will not be able to cope with the extra load to the engine. you could try to fool it to think the air con is on but I would suggest some sort of "piggy back" ECU to add the extra fuel you need.
Sprinter Veteran
so you have a 4agze with a sc14 from a 1ggze and the standard supercharger computer.
Steve
Insert witty comment here....
