Better now than later. Least you're not out on the track and shit fucks up.
We found out what the case was...
Pulled the sump off and #4 just had no bearing, nothing!
My guess 1 of 2 things happened; either when it got a rebuild (dodgy at that) the 4th bearing was merely forgotten, or somehow the bearing has been worn down that much....
Glad i dont have bent rod or crank, but the crank is scarredso ive just got as much work to do.... just as well im finding this now
When I pulled my engine down to rebuild it, the bearing on number 4 rod just fell out.
(there usually held in tightly)..
Asked my engine builder freind why, and he said its from detonation.
Perhapse number 4 gets alot hotter than the other cyclinders causing it suffer detonation, and then hammer the shit out of the rod bearing.....
Good luck V-tec.... Fingers crossed your crank isn't to dammaged or cracked....
Very keen to see your car with some more grunt...
Cheers mate, and thanks guys for your help and info
