Results 1 to 6 of 6
Thread: Rocker cover oil leakage
    Oldschool Member
    Jan 2006
    OK, well my mate has an RA60 Celica and it has some oil leaking from holes in his rocker cover (pictured)
    do you know if its possible to fix this with gasket silicone, or seal them up by any other means? or will this harm the engine?
    What can he do to fix it, it gives him the shits! (no "get a new engine" replies please)
    thanks!
    Jonathan
    Take it apart. Clean. Re-assemble with a tube of silicon.
    Oldschool Member
    Jan 2006
    the whole motor or just the rocker cover?
    the oil is coming out the breather hole and the other one at the rear that goes into the carby.
    is it bad to block the breather?
    thanks
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    its extremely bad to block the pcv....do not...get a new seal/and/or a better fitting hose
    are u getting much blow by? as in much oil coming out of the exhaust?
    Oldschool Member
    Jan 2006
    ok we are gonna fix the pcv but as for the front one, the breather, what do we do?
    he used to have blue smoke out the exhaust a lot but its died down a lot recently.
    i take it you cant block the breather either but so much oil comes out.
    thanks for all the help so far
    First id find out why the oil isnt going into/out of the hoses.
    Exess blowby, hmm maybe.
    Id start with the PCV first, clean with carby/throttle cleaner and/or replace as required, maybe new cromets as well. (i think they used a type of rubber cromet for those motors)
    Steve
    Insert witty comment here....
  1. [SYD] 20V Rocker cover - cover only
    By jet111 in forum Cars or Parts Wanted
    Last Post: 16th November 2010, 09:36 PM
  2. 20v rocker cover
    By grantobius in forum Cars or Parts Wanted
    Last Post: 6th July 2009, 12:59 PM
  3. Rocker cover
    By damo46 in forum Technical - Questions
    Last Post: 2nd June 2008, 10:34 PM
  4. Rocker cover
    Last Post: 24th April 2008, 01:10 AM
  5. rocker cover stuck
    By Johnny_08 in forum Technical - Questions
    Last Post: 16th March 2007, 08:59 PM
