Results 1 to 9 of 9
Thread: smokey issues
    Jan 2006
    hey guys,
    i have a problem with my 86... weneva i dont drive it (i.e. dont start it) for a few days n then i cum 2 drive it, it pours out white smoke for a while.. 1nce i get driving it eventually goes away..
    It has a 4gze in it if that helps in any way?? im jus a lil confuzed coz if i dont let it sit there for a few days it isnt 2 bad and iv been checkin by oil regularly n im not loosin any... cant put my finger on what the prob is..
    has any1 got an idea?
    thanks,
    Danny
    are you sure your car isn't using oil cause i would think that a problem like this could be due to worn valve guides
    do you have trouble cranking it after a few days. ie takes it's time to fire up?
    Veteran biggo's Avatar
    Nick
    Noosa
    Its more likely theres condensation in the pipes. Mine did that and i mean ALOT of white smoke spat out of her after sitting on the docks in japan for ~6 months.
    Or... you got water in the cylinders somehow
    Ferny Grove
    leaking valve stem seals
    Jul 2009
    could be many things, stem seals.. but stem seals would leak as your decelerating down a hill also.. is it steamy, or is it clearly oil smoke? smell it.. you can easily tell the difference... might have a small crack in the head too..or leaking head gasket that breaches a cylinder.. hows your water?? run a compression test, and if you can a leak down test... see any car manual for detailed reference how to do this..
    Jul 2009
    white smoke make me think it's a head gasker, or cracked head.. oil smoke is bluey most of the time..
    Nick
    Noosa
    Yay i remebered my facts for once
    Thanks for confirming Matty
    Poh
    Bevo
    i know ive gone grave digging
    but is driving ur car with worn stem seals very risky?
    say for about 10 mins to the local mechanic?
    Oldschool Member
    Apr 2005
    That will be fine.
    They tend to only smoke on startup, mebe a little bit on the de-accel like matty said. Plenty of 4a's with leaky valve stems around
  1. Smokey 4AGE?
    By bally in forum Technical - Questions
    Last Post: 6th March 2011, 12:57 PM
  2. Replies: 20
    Last Post: 4th October 2010, 03:05 PM
  3. starting issues...
    By dori_86 in forum Technical - Questions
    Last Post: 14th November 2009, 12:40 PM
  4. still got smoke issues
    By Nic19 in forum Technical - Questions
    Last Post: 10th November 2009, 10:42 AM
  5. wiring issues
    By Faceplant456 in forum Technical - Questions
    Last Post: 19th October 2009, 05:03 PM
