yep well thats going to happen when you get a longer lca, thats why ra40 outer tierod ends and rackends are used
fuck no wonder i didnt have major ass raping camber, i must have got this shitty sigma arms, ive only got -3 degrees on a side, my ball joints are pressed in. Ahh well got camber tops now, besides -3 degrees is a realistic good amount.
wheelfriends.wordpress.com
the informative part of this thread would go well in the wiki, I will look to add it if I get a chance in the future unless someone can do it before me?
<div class='quotetop'>QUOTE (Sam_Q @ Nov 17 2007, 12:14 AM) </div>do it sam, i tried to add the thing about KE70 strut tops in an AE86 for added caster, but got bored before i figured out how to do indexes etc
i got a max of 3 degrees when i used sigma arms, but im using those supra/celica struts that when on an ae86 they give you max of about 1 degree positive camber.
<div class='quotetop'>QUOTE (fixeruperer @ Nov 17 2007, 01:48 PM) </div>
was that with camber tops dude??
standard camber tops.
but now that i had to get the car licenced (wich it is now woohoo) i had to put the standard ae86 arms in and now im back to 1 degree pos(i cant be botherd putting the sigma ones in juts yet
an old pic.
wow all this is a little bit too much information at once...
i need a yes or no an0swer please.. today i purchased xt130 c/arms from u-pull-it.
am i correct that the xt130 steering arms wont bolt up to the strut?
so i have to press my ke70 steering arms into the control arm?
then i should be sweet to go?
xt130 steering arms will fit well, the ke70 ones wont fit they are 1mm off
<div class='quotetop'>QUOTE (Sam_Q @ Dec 29 2007, 07:50 PM) </div>any one know about t18 ones fitting?
