Page 13 of 17 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 121 to 130 of 170
Thread: Got Camber?
    Jan 2008
    <div class='quotetop'>QUOTE (anastasios @ Feb 22 2008, 11:09 PM) </div>
    Yeah I couldn't believe they were still available.... about $50 for the pair (trade) and I got the tie rod ends new too under $40.. so all new would be under $90.... not too bad!!!
    stefan
    vic
    eastern suburbs
    i have a question as to whats the best way to get some camber on an ae86 + ra60 struts? I'm assuming that the struts have just been bolted into the car with no other bits changed so I'm assuming that it has stock ae86 everything else, therefore there is no camber what so ever.
    what is going to work to get some camber? order some fuck off sized -rca's or corona lcas, combination of both or all of that plus camber tops???
    i want to keep the struts either way because of the braking goodness
    so what should i do???
    i put XT130 arms in my ke70, handles so much better! like a little go kart!
    i recommend the XT130 arms
    Oldschool Member
    Mar 2007
    After reading this whole thread didnt find the info i needed so...
    1. - If you have an ae86 and you get GH sigma LCA's you need ra40 tie rod ends and thats it?
    2. - Or do you need the ra40 tie rod as well?
    3. - Do you need to modify anything else? EG - swaybar mount hole, inner bush crush tube(grind down)?
    Stefan
    Parkinson
    dude its factory replacment arm for e7 etc
    just 10mm longer per side for xt 130
    and you can use ur original tie rods etc
    don't USE SUCKASSMA SIGMA ARMS WRONG TAPER
    Oldschool Member
    Mar 2007
    Can someone just answer my question please
    Stefan
    Parkinson
    yup don't use sigma arms
    Rob
    Moorabbin
    <div class='quotetop'>QUOTE (dog89 @ Apr 22 2008, 07:24 PM) </div>1. no
    2. yes, you said it yourself
    3. yes, yes
    4. JUST GET CORONA ARMS PLEASE
    Veteran biggo's Avatar
    Nick
    Noosa
    I should run SIGMAHHHZZZ just to piss you guys off
    Stefan
    Parkinson
    <div class='quotetop'>QUOTE (biggo @ Apr 22 2008, 07:49 AM) </div>
    then you would earn FAIL too
  1. WTB: ae86 camber tops/ camber plates
    By ae8620v in forum Cars or Parts Wanted
    Last Post: 12th August 2010, 09:29 PM
  2. FS strut brace, cusco camber top, neg camber RCA's
    By ae71 in forum Car Parts For Sale
    Last Post: 20th April 2009, 04:14 PM
  3. Camber from camber tops
    By eightsixboy in forum Technical - Questions
    Last Post: 5th October 2007, 10:58 PM
  4. More camber
    By _matt in forum General Topics (No Technical Questions)
    Last Post: 7th October 2006, 04:35 PM
