Page 17 of 17 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17
Results 161 to 170 of 170
Thread: Got Camber?
  1. #161
    Veteran Konakid's Avatar
    Henry
    Eastern
    <div class='quotetop'>QUOTE (Ksevn-T @ Oct 2 2008, 11:06 AM) </div>Depends on you tyre and what rim its on but -3 is plenty for a street tyre.
  2. #162
    Rob
    Moorabbin
    -2 - 2.5 is plenty
    youll know if you need more
  3. #163
    Veteran johl's Avatar
    Johl
    i run neg 2.5. u can really feel that the tyre has max grip during heavy cornering so i know thats pretty much the sweet spot for my set up
  4. #164
    A
    Parky
    3 degrees is too much for a daily drivien car,
    1.5-2 is way more practical and wont chew out tyres as quick.
  5. #165
    Henry
    Eastern
    between -2 to 2.5 is sweet.
  6. #166
    Veteran slydar's Avatar
    Dimitri
    i think 3ish is good. if you do a fair amount of hard driving and drifting your tires will wear evenly even at that setting. with drift you intentionally throw the car onto the outside loaded wheel really hard, so the recommendation of 1.5-2 degrees being the most you can take advantage of with a road tire doesnt really apply to a drift car.
    the extra camber helps with wheel fitment too. i would rather have too much camber than too little.
    78's
  7. #167
    Veteran driftke70's Avatar
    Ryan
    Buderim
    indubitably,
    another cool thing to do if you ever get bored, can be used for various applications, but basically get a piece of chalk and draw a line going from your trread to a little way up your sidewall, and after a bit of driving, depending on what you are building the car for, you can see how much your tyre is actually rolling outwards, how much of your tread has actually hit the black top.
    wheelfriends.wordpress.com
  8. #168
    Henry
    Eastern
    <div class='quotetop'>QUOTE (driftke70 @ Oct 2 2008, 08:04 PM) </div>Fucking good idea.
    Have also read that by using temp sensing gun on the inner, middle and outer part of the tyre after a hard run will tell you whether you need to run more or less.
    I'm under the impression that the bigger the sidewall, the more camber you should run as the tyre will want to 'fold' over more than a low profile tyre.
    eg compare 195/50 to a 185/60.
  9. #169
    Troy
    Baulkham hills
    <div class='quotetop'>QUOTE (slydar @ Oct 2 2008, 06:07 PM) </div>..just dont try and pull quickly in a straight line as you have bugger all front tyre tread contact! Your usually better to have more castor then just loads of camber, as caster adds dynamic camber when turning.
  10. #170
    Henry
    Eastern
    <div class='quotetop'>QUOTE (HighLife @ Oct 3 2008, 12:40 PM) </div>Definately, camber is the enemy of straight line braking!
  1. WTB: ae86 camber tops/ camber plates
    By ae8620v in forum Cars or Parts Wanted
    Last Post: 12th August 2010, 09:29 PM
  2. FS strut brace, cusco camber top, neg camber RCA's
    By ae71 in forum Car Parts For Sale
    Last Post: 20th April 2009, 04:14 PM
  3. Camber from camber tops
    By eightsixboy in forum Technical - Questions
    Last Post: 5th October 2007, 10:58 PM
  4. More camber
    By _matt in forum General Topics (No Technical Questions)
    Last Post: 7th October 2006, 04:35 PM
