AFAIK the variation between the 2 isn't 1/2 or 3/4 the first line is about 40psi.. which is normal operating temp/ pressure, and the 2nd line is about 80 psi.. as long as your running a good 20w50 in your 4AC you should see good oil pressure.. give or take a little on the gauge, as long as it's not reading lower than the 1st line when driving/at revs.. if it sits between is pretty normal..
