Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 31 to 40 of 89
Thread: Diffs n shit
  1. #31
    Paul
    Gold Coast
    Only OEM and TRD LSD's need axle shortening. Most other aftermarket diffs dont need shortening. I can tell you for sure Cusco's dont.
  2. #32
    May 2010
    Jason
    so is the ra40 the same as the 60?
  3. #33
    May 2010
    Ashley
    Hi, i have a ra40 diff in my sprinter, bolts in no worries, the top mounts sit 5mm out on each side i think, i got a whiteline adj panhard rod and got them to make it adjust further out, it is 1410mm wide which is 20mm wider than the s series diff by my measurments, this is a cheaper way of getting a t series diff than t18, wreckers seem to want a bit for them these days, dont forget the tail shaft, this cost me $80 which is crazy for a tail shaft. my 2c
    Ashley
  4. #34
    Oldschool Member
    May 2005
    has anybody used a TA23 4.3 ratio centre???
  5. #35
    Veteran slydar's Avatar
    Dimitri
    4.3 is extremely rare. 4.1 is common. either will fit.
    ra40 diff fitment sounds dodgy. recently bought one for the ratio/axles. bottom arms are indentical spacing, tops are out, flexing the arms bush to make them reach the top mounts is not a good idea, especially on a lowered car. fucked out all bushes probably helps but once your upper control arms are pointing up already + twisted over. its just not good.
    also the springs seats are a differant style.. smaller diametre at a glace? didnt bother measuring spacing.
    78's
  6. #36
    Oldschool Member
    May 2005
    so to end a long story will a ra60/ta23 4.1 ratio centre bolt into a t-18 diff and will the t-18 axles bolt in?.so basically u jus swap centres over.
  7. #37
    Dimitri
    yes. just bolt it in. spline and bolt pcd/everything is the same. dont think youll find a t292 ra60 though. more likely ra40. (t292 is the axle code youre looking for, on the build plate)
    T= t series obviously. first 2 numbers are the ratio code. 28 = 4.3 29 = 4.1 30 = 3.9 ect. 2 is the nember of pinion gear/lsd or not. 2 = 2 pinion gears, 3 u 2 pinion gears + lsd, 4 = 4 pinion gears, 5 is 4 pinion lsd.
    78's
  8. #38
    Oldschool Member
    May 2005
    cheers slydar for the info and yes ive got a copy of the axle codes
  9. #39
    Elite rthy's Avatar
    Leo
    Tulla
    Does the rear RA60 tailshaft half bolt with the ae86 front half? or do you use a shorter one? or t18?
    heres some stock spec with track width:
    AE86
    F 1335
    R 1345
    RA40
    F 1330mm
    R 1350mm
    RA60
    F 1395
    R1395
    SA63
    F 1395
    R 1385
    AE71
    F 1320
    R 1345
    T18
    F 1325
    R 1335
  10. #40
    Dimitri
    where did you get those specs?
    78's
  1. 4a shit, X members,Cam gears, Cams, HEAPS OF SHIT!
    By lolwat in forum Car Parts For Sale
    Last Post: 13th December 2012, 08:56 AM
  2. free shit, it is shit though, brissy
    By Gilly in forum Car Parts For Sale
    Last Post: 12th May 2009, 10:35 PM
  3. diffs
    By rolla92 in forum Technical - Questions
    Last Post: 25th April 2009, 05:28 PM
