How much do you have to shave off the t18 drum axles to fit a TRD 2way in? whats the best way of shaving them?
on drive.com or redbook
then seem to be spot on, well with the 86 n 71 anyways
IMMORTAL IMAGEStattooing & body piercing
home of the dori oni tattoo
Is there any reason people dont consider building their own diffs? I find the assurance of having massively fat axles/centre is worth the bit of extra cash used to make it.
Eddie.
how much is it to get a custom diff? ive always had that in mind but always though it would be a rather expensive option?
They can usually be built for around 1.5k to 2k depending on the setup and how many bearings/seals need to be replaced. I usually make G-series diffs with disk brake setups. Pm me if you want more info.
Seeing as disk brake T-series rear ends go for around1.5-1.6k, having the assurance that it'll NEVER break for an extra few hundred is worth it in my opinion.
Eddie.
LSD as well? if so thats a sweet price
Yeah for the upper price range, they normally include clutch pack LSDs.
Eddie.
hey guy i got a trd lsd centre going into my t18 diff hsg, was chasing specs for bearing preloads and and seting the pinion and crown clearence
yeah but you still have to set preload on the bearings go to tight and they will sieze etc.
