Page 4 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 31 to 40 of 124
Thread: things from other cars that replace stock sprinter bits
  1. #31
    Elite rthy's Avatar
    Leo
    Tulla
    i used a ae82 fwd clutch slave cylinder on my t50 cos it looked cool
  2. #32
    hilux, supra aswell
  3. #33
    Veteran driftism's Avatar
    Andrew
    Watsoia
    i think it's just about any car with rectangular lights
  4. #34
    Nat
    Newcastle
    Pretty much all cars with rectangular pop ups use a standard size semi sealed beam light (as do ke70's). You can get uprated versions of these heaps easily with better reflector buckets. Mate has them in his jza70 and they are awesome, even with normal globes.
  5. #35
    Senior Member ToySprinta's Avatar
    Steve
    Padstow
    Doing a w5* g/box conversion and found ount some helpful hints
    A HiAce clutch slave is the same ID bore as the sprinter one, but its for the drivers side
    A RA70 W58 Thrust race and gearlever will fill a W58
    And a RA70 front t/shaft section and a T18 rear will bolt a W58 to a T-series rear end.
    Be doing a write up soon with part numbers and everything so people don't have to do all the stuffing around im doing now
  6. #36
    parrot
    A very basic one. If you pull out your aircon but still want the heater to work, as it must for RWC, get the plastic adaptor off the side of the heater core box and the duct across to the heater blower fan, from a non air con AE71. Factory.
  7. #37
    Andrew
    Watsoia
    would this be the same for a non-aircon Ke70?
  8. #38
    Jul 2009
    Kane
    Coburg
    could you explain a little bit more?
  9. #39
    Andrew
    Watsoia
    well i've only got half a heater box, and there aren't any fans on it, so i assume theres a plastic tube or som,ething that fits in between the fans and the heater on cars that have no A/C, but i'd like to hear more as well
  10. #40
    parrot
    If you pull out the heater/aircon unit from under the dash of your AE86, you will note there are three sections. In the centre of your underdash area is the heater core. The actual fan unit is over in the left hand corner. The aircon refrige box is in the middle. When you pull off the aircon crap from the engine bay, may as well pull out this bit too.
    The AE71 (without aircon) has a plastic bit that slots in to the left hand (open) side of the heater core box when you remove the aircon section from your AE86. This held is in with two screws. Essentially it is an adaptor to fit a piece of ducting which slips onto the side of the fan box. Thus you can have a heated demister etc. Costs bugger all for the two bits from Nick a part. Possibly the same as a KE70?
  1. things from other cars that replace stock sprinter bits
    By Jonny Rochester in forum Offtopic Discussions
    Last Post: 9th January 2007, 10:41 PM
