I almost finished my outlet pipe:
now all I need to do is drill a hole and weld on the pipe that suits the thermostat bypass water. It turned out better than expected and fits on the engine real nice (pic soon). I cut the flange myself, used a peice of bent pipe from a truck mirror mount welded to a peice of exhaust that I machined grooves into to seal the water. The outlet on the head was an oval shape so I welded on one pipe and then used a second peice welded on on an angle to cover the hole and provide unrestricted water flow, this was not an easy job but turned out good enough.
Now a question for the ae-86 gurus who read this:
-What is the stock redline cutoff?
-whats a place that the body bends in an adverse way to handling? apart from the strut towers?
