hey guys im having trouble with my AUS SPEC Sprinter (4AC) I have left the car unattented for a month or two and when I went to start it the clutch pedal felt like there was no resistance or pressure you couldn't make out the friction point at all pretty much there was nothing there, anyways when I went to engage it into first gear it wouldn't let me (let alone any of the other gears), as if the clutch wasn't releasing?!
so then i turned off the car and attempted to put it into gear while holding down the clutch pedal to some how start in first gear but still it didnt work its as if the clutch pedal has no control over the clutch? I think its possibly the clutch release cylinder or the master cylinder but before i start ripping everything to try and find out the problem i was wondering if anyone has encountered this problem before or have any ideas on the issue? I really need this car to get to work as this was intended to be my daily driver thanks for your help
-T.
