Results 1 to 3 of 3
Thread: ciggy lighter not working
    hi guys im wiring up an el cheapo diy cd player..and found out that my ciggarette lighter is not working..any1 can help?..on my other car i used to look up the fuse box 1st if anythings wrong..but obviously doesnt apply for my stoko 4ac sprinter coz i cant find a fuse for theciggy lighter
    Member kane's Avatar
    Kane
    Vic
    Apparently there is a CIG 15A fuse, somewhere, so look for that first.
    Or just grab a multimeter and see if it has 12V at the socket. If it does, then it might not be connecting with whatever you are pluging into it.
    On my other car, I once had to bend out the middle 12V pin to make contact. Over time with heat they can bend themselves away and loose connection.
    Senior Member DavisJD's Avatar
    might not be much help, but mine use to not work. Unplugged the plug out of the back and put it back in and it worked, so probably the problem would have been what Kane just mentioned
  1. Tacho not working.
    By BON35 in forum Technical - Questions
    Last Post: 7th November 2012, 10:47 AM
  2. KE70 with working A/C!
    By squish_m8 in forum Cars for Sale (Toyota Only)
    Last Post: 9th January 2012, 02:16 PM
  3. WTB: Cigarette Lighter/Adaptor 12V
    By li21 in forum Cars or Parts Wanted
    Last Post: 12th May 2008, 05:11 PM
  4. How to make the steering feel lighter
    By slydar in forum Technical - Questions
    Last Post: 2nd January 2006, 02:43 PM
