Results 1 to 10 of 13
Thread: how to clean oil spill or leak in drive way?
    Elite rthy's Avatar
    Leo
    Tulla
    any got some tricks? i normaly used meth to clean it up.. but this time i dont think i have enough!
    took the sprinter for one last spin in the old bigport b4 changing over to jdm bigport ( )... anyways i took it for a spin around the block and it left a engine oil trail from the garage and back! you can see where i drove! and left a nice little trail on the drive way as well...
    so whats a good solution to clean it up? CLR? acid? cheap cola?
    couldnt find anything on search or google
    except for this but donno if its anygood?
    Jul 2009
    go to supercheap in the degreaser section is this Koala brand degreaser.. buy a 5L bottle.. it's a water based degreaser not solvent based.. so wont kill grass etc as bad.. mix it up with some boiling water.. let it soak on it.. then gurnie or scrub it off with a broom
    Senior Member otomoto's Avatar
    Dec 2009
    Parramatta
    Matty, just out of curiosity, will this only work on a pretty fresh stain, or will it lift old stuff as well?
    Cheers,
    Jeremy.
    Jul 2009
    anything.. it's also really good to use to degrase under your engine bay, as it doesn't harm paint like normal solvent based degreaser can...
    Jul 2009
    you are ment to duliout it but the stronger you make it the easier it will lift old stubborn oil stains like off concrete etc...
    Will
    dishwashing liquid, liquid magnet, washing powder and scrubbing brush
    or you could coat the whole driveway in oil, even it out.
    Elite rthy's Avatar
    Leo
    Tulla
    i think ill try that koala stuff insted of "coat the whole driveway in oil, even it out"
    lol
    thanks
    Julz01
    Or grab the CT-18 degreaser which is a concentrate which will be alot stronger then kola branded one.
    Im pretty sure even the kenco degreaser is a concentrate so that would be good to try as well
    Ian
    NOR
    what i'd do is put newspaper on all of it to soak up as much as you can, then remove newspaper and spray kerosene and let it soak for a while then wipe off.
    Oldschool Member
    Sep 2005
    I just use degreaser.
  1. Replies: 26
    Last Post: 2nd February 2011, 05:44 PM
  2. Oil change -> Oil leak problem
    By Driftspec in forum Technical - Questions
    Last Post: 26th November 2009, 04:12 PM
  3. oil leak
    By Fozz in forum Technical - Questions
    Last Post: 6th April 2009, 05:56 PM
  4. Serious 4AGE oil leak
    By Golberg in forum Technical - Questions
    Last Post: 21st July 2008, 12:22 AM
  5. Dizzy oil leak
    By wide s13 in forum Technical - Questions
    Last Post: 26th May 2006, 10:02 AM
