I have built a similar small port motor.. with quads, portwork, more compression, bottom end bearings/rings etc.. and linished rebalanced the rods.. has adaptronic ecu.. with the stock smallport 232 deg and 7.1mm lift it makes about 104rwhp..but feels a lot stronger than that.. the dyno does have some calibration issues.. but with cams around the 280 duration and 8ishmm of lift I would be expecting in the area of 135-140 rwhp.. that is a estimate..
