Results 1 to 10 of 10
Thread: Steel head gasket part no#
    Oldschool Member
    Apr 2006
    Anyone know part number for a steel head gasket for a 4agze with 4age head?
    Also how thick should it be?
    Oldschool Member
    Apr 2006
    anyone?
    Mar 2005
    dont know any part No.'s man but heard that the stock gaskets arnt such a bad thing.... unless of course you want to change comp ect...
    Veteran slide86's Avatar
    Huw
    Hills
    i have a HKS metal head gasket on my 4agze with a bigport head.
    part number is 11116-018158a0
    Its 2.0mm thick and is metal.
    Oldschool Member
    Apr 2006
    expensive?
    Huw
    Hills
    yeah it was a bit. but i had to get it in from japan. thats why...
    its would cost the same to get your block o-ringed with a standard gasket. should have no worries then
    Eddie
    Thickness will depend on what CR you want to run. If you're using a metal hg, it's a good idea to deck the block/head to ensure an even surface. When they do this, they shave a small amount off both the head and block... find out the exact amounts they take off and then get a hg to suit.
    I'm using a HKS 1.6mm hg with 8.9cr GZE pistons but my actual cr is closer to 9.1:1 due to decking. I decided not to use the 2mm to keep better squish areas.
    If you're looking for other brands, i think Cometic also have a mhg for a 4ag.
    Eddie.
    Huw
    Hills
    yeah i had my block decked and head faced twice.
    so with the 2.0mm it probably wont alter the comp ratio heaps
    Sep 2005
    11115-16070 @ 84.70 Retail Inc..
    Guys if there are any 'part' related questions PM me as I work in parts for toyota and I dont mind helping out..
    Jul 2009
    i got genuine TRD 3 layer metal head gaskets for $88 delivered the more i ordered the lower the price.. cheapest i could get them 4 was $66.. but sadly didn't get a chance to order them as the TRD wholesaler doesn't do TRD parts anymore! lucky i scabbed a 0.5mm and a 0.8mm one..
    yes cometic do a metal HG.. i used a 1mm one in my GZE.. i'd advised against getting a maaaaassive gasket.. just so you can run big boost and a big turbo.. rather get a turbo to suit your engine biuld.. not the other way round.. having a higher static CR and mild boost will give better torque and resopnse.. just not the wank factor of put your foot down.. wait... wait.... waaaaaait... woooooah!!! boost!
  1. Head gasket part numbers ??
    By driftnick13 in forum Technical - Questions
    Last Post: 21st July 2009, 11:42 PM
  2. 20v exhaust gasket part number..HELP
    By 70fun in forum General Topics (No Technical Questions)
    Last Post: 8th July 2009, 02:02 AM
  3. TRD .5mm rwd head gasket part number required...
    By shelldrake in forum Technical - Questions
    Last Post: 11th August 2008, 09:21 PM
  4. Part number: 20v intake gasket
    By skit in forum Technical - Questions
    Last Post: 10th October 2007, 08:58 AM
  5. 4age ARP Head stud Kit, toda 0.8 mm head gasket
    By rxbenny in forum Car Parts For Sale
    Last Post: 10th July 2007, 11:50 PM
