Results 1 to 6 of 6
Thread: Where top dead centre is
    Jan 2006
    Just want to make sure the top dead centre is when number one piston is all the way up and number 4 pistons is almost up. Trying to put timing belt back on. Its a 4ac
    Senior Member riceburner's Avatar
    I have the book out in the shed, ill have a look.
    Steve
    Insert witty comment here....
    It appears that the cam wheel has a small hole in it which needs to be lined up with the cam. Me thinks its a locking pin.
    And if you havent mucked around with the crank pully, just turn the crank till the notch on the pully lines up with the 0 on the timing marks.
    You could also remove n# 1 spark plug and install a long piece of skinny wood or metal and turn crank till you find the top of n# 1 cycle.
    Steve
    Jan 2006
    It was my boyfriend fixing it for me.. He mainly just wanted to know if it had to be all the way up.. He sat there trying to come up with excuses to not start it while I was there in case it was wrong, I think he thought he would die if it stuffed up.. It worked but so he jumped around and screamed I was right I was right for a while and now my jacket is all greasy.
    Thanks for looking that us for us but, much appreciated.
    Sep 2005
    Has he ripped the dizzy out as that can also f**k up your timing..
    Need a swearing filter!!!
    Jan 2006
    Ah we checked it last night and the timing is perfect now. I just realised I have a hole in my water pump though so getting one of those today.
  1. Replies: 2
    Last Post: 30th September 2011, 04:35 PM
  2. top dead center
    By nesta in forum Technical - Questions
    Last Post: 1st February 2011, 07:23 PM
  3. Wanted: Dead 4AGE alternators & starters, Dead T50's
    By Golberg in forum Cars or Parts Wanted
    Last Post: 7th January 2011, 08:49 AM
  4. Open centre zenki type T Diff centre + front snout
    By LordNafe in forum Car Parts For Sale
    Last Post: 21st May 2010, 12:58 PM
  5. GZE, dead mid to top end
    By ae86 slide in forum Technical - Questions
    Last Post: 19th May 2009, 08:01 PM
