Results 1 to 10 of 12
Thread: which manifold
    Oldschool Member
    Apr 2006
    hi guys my question is this. im building a a4gte using a bigport head. what manifold is the best to use. the 100kw 8 runner one or the fwd 4 runner one, and change the throttle body position. i could make a custom one at work but i dont have the time for that atm. any help would be usefull
    Will
    bigport head use bigport manifold
    smallport head use smallport manifold.
    it really is that simple.
    Oldschool Member
    Apr 2006
    yeah but ive seen small port intake on bigport head, which is ment to flow well. just hoping someone else had carried ou some sort of testing into this to confirm this or not.
    Apr 2011
    Steve
    The port spacing is different as road sailing said small port on smallport......
    Sprinter Veteran
    Will
    oh yeah, forgot about that.
    incicently, the port spacing of smallport and silvertop 20 valve is basically identical
    Oldschool Member
    Apr 2006
    if the port spacing is different how is it that people have used the small port to big port configuration. spacer plate?
    Will
    the bolt holes line up, the air holes do not line up.
    also, the 100kw(smallport) one is a 4 runner, bigport is 8 runner.
    Oldschool Member
    Jan 2006
    T3 made a adaptor plate for using bigport manifold on a smallport head.
    Veteran slydar's Avatar
    Dimitri
    the adaptors channel the offset runners into the ports.
    id just use a big port manifold. any differance will be neglidgable not at all worth the trouble. highly unlikely anyone is going to be able to give a proper oppinion based on back to back testing.
    78's
    Oldschool Member
    Apr 2006
    guys in slightly confused on the bigport 86kw head, the maching inlet manifold has 4 runners and if put on a rwd set up needs the throttle body swaped to the other side. is this correct?
  1. VIC FWD 4age inlet manifold, FWD Exhaust manifold
    By KE-DORI in forum Car Parts For Sale
    Last Post: 30th June 2012, 08:38 PM
  2. Wtb rwd inlet manifold big port inlet manifold
    By armc89 in forum Cars or Parts Wanted
    Last Post: 19th November 2010, 12:09 PM
  3. Replies: 4
    Last Post: 1st September 2010, 01:47 PM
  4. RWD Intake Manifold and FWD Intake manifold
    By omygtr in forum Car Parts For Sale
    Last Post: 17th April 2009, 07:13 PM
  5. WTB:RWD 4age intake manifold, exhaust manifold
    By djscheppy in forum Cars or Parts Wanted
    Last Post: 8th June 2008, 06:39 PM
