You would not make more power unless the smaller turbo's exhaust housing was restricting the engine.
1 bar pressure is 1 bar nomatter what turbo you are using. Since you are compressing the air to the same pressure, and you have the same manifold volume the temp will raise to the same level (Boils law) P1V1/T1=P2V2/T2
