which engine is this for?
otherwise great work
All other tech forums have one, so should we
I start with the ones I know.
ARP main cap studs Part number: 203-5403
ARP head stud kit part number 16V: 203-4203
ARP rod bolts 203-6001
ACL main bearings Part Number: 5M1695HX
ACL Rod bearings Part number: 4B1780HX
ACL piston rings Part number : C1806
ACL Timing Belt Tens TT1025
ACL Gasket set Full GR901MT
ACL thrust washers Part Number: 2T1695
Water Pump Repco W1063
Toyota 20v head bolts 9091002106
Toyota 20v head gasket 1111516111
Toyota 16v head gasket 0411116113
Toyota Oil Pump Part number: 15100-19036
Toyota Thrust Washer 1101115020
Toyota Pistons AW11 131011610002
Toyota Pistons AW11 Ring Set 1301116090
Toyota Pistons A111 hi comp 131011613101
Toyota Pistons A111 hi comp ring set 1301116210
HKS head gasket: 11116-018158AO
Add to the list as I find out more
ACL stuff is the same for 20v or 16v but ACL gasket set is for 16v
dude if you want part numbers give me a call i work for repco and own acl, hks etc catolog
this site has some body part number
JDM PARTS # for AE86
NOTE: USE WITH CAUTION
SPRINTER TRUENO PARTS
KOUKI Front Bumper 52119-12092 $134.18
KOUKI Front Bumper Bracket R 52011-12221 $45.77
KOUKI Front Bumper Bracket L 52012-12221 $45.77
KOUKI Front Turn Signal Lamp Assy R 81510-80038 $55.45
KOUKI Front Turn Signal Lamp Assy L 81520-80038 $63.92
KOUKI Front Grill 53100-12232 $26.98
KOUKI Front Grill Emblem 75314-12021
KOUKI Rear Bumper 52159-12062 $176.83
KOUKI Rear Bumper Bracket R 52015-12111 $33.65
KOUKI Rear Bumper Bracket L 52016-12111 $33.65
KOUKI Smoked Turn Signals 81731-12173 & 81741-12163
KOUKI Redline Tail Light Right 81550-1A291
KOUKI Redline Tail Light Left 81560-1A291
KOUKI Redline Tail Light Center Piece 52012-12221
ZENKI Front Bumper 52119-12140
ZENKI Front Bumper Bracket Right 52011-12230
ZENKI Front Bumper Bracket Left 52012-12230
ZENKI Front Lip 76081-12010
ZENKI Trueno Grill 53100-12231
LEVIN
ZENKI Levin Front bumper 52119-12090
ZENKI Levin Hood 53301-12340
ZENKI Levin Right Fender 53801-1A860
ZENKI Levin Left Fender 53802-1A560
KOUKI Levin Right Fender 53801-1A770,1E370,1A861
KOUKI Levin Left Fender 53802-1A750,1A760,1A661
KOUKI Levin Front Bumper 52119-12142
KOUKI Levin Front Right Bumper Bracket 52011-12231
KOUKI Levin Front Left Bumper Bracket 52012-12231
KOUKI Levin Hood 53301-12340
PARTS
Sprinter TRUENO Decal Coupe - 75441-12320-03
Sprinter TRUENO Decal Hatch - 75441-12321-03
APEX TWIN CAM 16 Decal 75443-12550-03
APEX TWIN CAM 16 Decal 75443-12551-03
GTV Hatchback Stickers 75985-12380
TRUENO Mudflaps - 76608-19265 & 76607-19265
OEM Sideskirts 76901-12010 (left)
OEM Sideskirts 76902-12010 (right)
TRD Rear Hatch 67005-AE801-60
TRD Rear Hatch Wing 64440-AE801
TRD Carbon Fiber Hood 53311-AE820
TRD 2Way LSD - 41301-AE804
TRD 1.5Way LSD - 41301-AE805
TRD Trueno/Levin Bible 00602-05100-550
TRD Strut Uppermounts: 48603-AE851 & 48609-AE851
TRD Rear Springs Blue/Orange dot: 48231-AE801-60
TRD Front Springs Light blue/Red dot: 48131-AE801-80
TRD Front (6kg/mm): 48131-AE801-60
TRD Rear (6kg/mm): 48231-AE801-60
Camshafts: PART NO. TYPE ANGLE
13501-AE851 IN 304
13501-AE861 IN 288
13501-AE871 IN 272
13502-AE851 EX 304
13502-AE861 EX 288
13502-AE871 EX 272
KOUKI TRUENO
Front Bumper $134.18
52119-12092????
Front Bumper Bracket Right $45.77
52011-12221????
Front Bumper Bracket Left $45.77
52012-12221????
Bumper/Clearance/Turn Signal Right $55.45
81510-80038????
Bumper/Clearance/Turn Signal Left $63.92
81520-80038????
Front Grill $26.98
53100-12232
Grill Emblem $17.00
75314-12021
Rear Bumper $176.83
52159-12062????
Rear Bumper Bracket Right $33.65
52015-12111????
Rear Bumper Bracket Left $33.65
52016-12111
Redline Tail Light Right $181.46
81550-1A291
Redline Tail Light Left $181.46
81560-1A291
75803-12070
Black Limited Trueno Emblem $27.63
75314-12030
ZENKI TRUENO????????
Front Bumper $95.59
52119-12140????
52011-12230 DISCONTINUED
52012-12230 DISCONTINUED ??
Zenki Trueno Front Lip $586.57
76081-12020
Zenki Grille Emblem
75314-19015
Rear Bumper Bracket Right $57.36
52015-12110
Rear Bumper Bracket Left $57.36
52016-12110
Rear Bumper $350.78
52159-12091-08 (only part number available right now, "-08" prefix signifies a color, so
this could be a white painted bumper!)
Rear Bumper Seal, left? $5.21
52591-12010
SHARED PARTS????????
APEX Twin Cam 16 Decal $10.46
75443-12550-03????
GTV Decals $20.53
75985-12380????
Smoked Turn Signals $11.08 each
81731-12173 DISCONTINUED
81741-12163 DISCONTINUED
Sprinter Trueno Decal Coupe $21.86
75441-12320-03????
Sprinter Trueno Decal Hatchback
75441-12321-03
TRUENO Decal (black)
75442-12790-03
Trueno Mudflaps $52.79 each
76608-19265
76607-19265
OEM Sideskirts
76901-12010 (left) DISCONTINUED
76902-12010 (right) DISCONTINUED
TRD JAPAN????
Rear Hatch
67005-AE801-60????
Rear Hatch Wing
64440-AE801????
Carbo Fiber Hood
53311-AE820
Thermostat 71'C, 160'F
90916-03046
TRD USA
Quickshift Kit $199.74
00602-30301-002
Front Sway Bar
00602-48810-001
Lowering Springs
00602-48130-001
Oil Filler Cap-Kanji screw-on
00602-12108-001
Oil Filler Cap-Japan screw-on
00602-12108-002
Radiator Cap 18.5 psi
00642-16401-001
Radiator Cap 21.3 psi
00642-16401-002
Plug Wires (race)
00642-90919-000
Headers - new revision - (race)
00642-17141-012
Valve Springs (race)
00643-90501-000
Cam Gear 4AG (adjustable)
00642-13523-001
Fuel Pressure Riser (adjustable)
00643-23280-000
Metal Head Gasket
00643-11115-000
Clutch Kit (street)
00642-31200-020
Clutch Kit (race)
00643-31200-021
Oil Filter (race)
00642-90915-002
Front Shocks (pair)
00602-48511-031
TRD JAPAN AE86 Lowering Springs
Fronts: $58 each
Rears: $41 each
NOTE: Each part # represents ONE spring, not a pair or set!!!
Front Springs2.0kg/mm (rally)
48131-AE851
Front 2.4kg/mm (rally)
48131-AE861
Front 6.0kg/mm (race)
48131-AE801-60
Front 8.0kg/mm (race)
48131-AE801-80
Rear 2.3 kg/mm (rally)
48231-AE861
Rear 3.9 kg/mm (race)
48231-AE801-39
Rear 4.3 kg/mm (race)
48231-AE801-43
Rear 4.7 kg/mm (race)
48231-AE801-47
Rear 5.1 kg/mm (race)
48231-AE801-51
Rear 5.5 kg/mm (race)
48231-AE801-55
Rear 6.0 kg/mm (race)
48231-AE801-60
Rear 6.5kg/mm (race)
48231-AE801-65
Rear 7.0kg/mm (race)
48231-AE801-70
Rear 8.0kg/mm (race)
48231-AE801-80
Rear 9.0kg/mm (race)
48231-AE801-90
New TRD JAPAN
TRD GAUGES
Control Unit
83291-SP000
Tachometer $217.50
83270-SP030
Boost Gauge
83550-SP000
Oil Pressure Gauge
83510-SP020
Oil Temp Gauge
83580-SP020
Water Temp Gauge
08580-SP020
Zenki Levin
Zenki Levin Bumper $130.18
52119-12090
Zenki Levin Front Left Bumper Bracket $44.99
52011-12220
Zenki Levin Front Right Bumper Bracket $44.99
52012-12220
Levin hood $232.18
53301-12340 #UPDATED, please use 53301-12442
Grill $90.80
53100-12220
Zenki Levin Right Fender $160.18
53801-1A860
Zenki Levin Left fender $160.18
53802-1A560
Zenki Levin Front Lip $386.53
76081-12010
Kouki Levin
Kouki Levin Right Fender $167.69
53801-1A770
Kouki Levin Left Fender $167.69
53802-1A760 or 1A661 ?
Kouki Levin bumper $139.50
52119-12142
Kouki Levin Front Right Bumper Bracket $34.98
52011-12231
Kouki Levin Front Left Bumper Bracket $34.98
52012-12231
Levin hood $232.18
Bumper Support $ 8.49 each (you need 2)
52115-12240
Bumper Turn Signal (left) $43.34
81520-80024
Corner Light (left) $55.30
81620-12290
Corner Light (right)
81621-12290 DISCONTINUED
Door Molding
75732-12251-08
Headlight (left) $204.30
81150-1A021
Headlight (right) $204.30
81110-1A261
FORMULA ATLANTIC 4AG
CYLINDER HEADS
Cylinder Head Sub Assembly 11101-16030
Cylinder Head Gasket, Metal, .8 11115-AE814
Cylinder Head Gasket, Carbon, 1.2 11115-AE802
Intake Valve Guide 11121-FT001
Exhaust Valve Guide 11125-FT001
Valve Guide Ring 90520-10004
Intake Valve Seat 33.12mmOD 11131-AE801
Intake Valve Seat (+.005) 33.28mmOD 11131-FT001
Exhaust Valve Seat 29.62mmOD 11135-AE801
Exhaust Valve Seat (+.005) 29.77mmOD 11135-FT001
Exhaust Valve Seat (+.014) 29.97mmOD 11135-FT002
Head Bolt, Intake (Short) 90109-10058
Head Bolt, Exhaust (Long) 90109-10059
Head Bolt Washer 90201-10344
Intake Manifold Stud 90116-08212
Bushing, Rubber Manifold Soft Mount 20103-SP001
Plate, Rubber Bushing Retainer 20104-SP001
Nut, Jetnut, Carb Mounting 94300-FT001
Intake Manifold Gasket 17177-AE801
Exhaust Manifold Stud 90116-10037
Exhaust Stud Washer 90201-10089
Exhaust Stud Nut 94181-11000
Exhaust Manifold Gasket 17173-FT002
Plug, Fuel Injector 20301-AE801
Gasket, Water Outlet 16341-16020
CAMSHAFTS/VALVES
Intake Camshaft 13501-AE881-D
Exhaust Camshaft 13502-AE881-D
Camshaft Timing Pulley, Stock 13523-16010
Camshaft Timing Pulley 13523-AE801
Camshaft Pulley Drive Bolt 91111-71020
Camshaft Pulley Washer 90201-10019
Dowel, Cam Drive Pulley 90250-05121
Camshaft Oil Seal 90311-35012
Intake Valve 13711-AE802
Exhaust Valve 13715-AE802
Valve Spring Seat Platform 13735-FT001
Valve Stem Seal 90913-FT001
Inner Valve Spring 26945-FT003
Outer Valve Spring 26946-FT003
Valve Spring Retainer (steel) uses 14mm shim 13741-FT002
Valve Spring Retainer (TI) uses 14mm shim 13741-FT003
Valve Spring Retainer (TI) uses 9.5mm shim 13741-FT004
Valve Lock (Keepers) 90913-03021
Valve Adjust Shim (order size required) 14mm 90072-00000
Valve Adjust Shim (order size required) 9.5mm 90072-FT000
Valve Lifter (Bucket) (Standard) 13751-FT003
Valve Lifter (Oversize) 13751-FT004
PISTON/CONNECTING ROD
TAC Piston W/Pin, Clips, Rings STD. 13101-FT031
TAC Piston W/Pin, Clips, Rings + .005" 13101-FT032
TAC Piston W/Pin, Clips, Rings + .008" 13101-FT033
Ring Set, TAC Piston, STD. 13031-FT001
Ring Set, TAC Piston, +.005" 13031-FT005
Ring Set, TAC Piston, +.008" 13031-FT008
Clip, Wrist Pin Retainer (Replacement) 13252-FT001
Connecting Rod TAC - 5/16 Bolt 13201-FT002
Connecting Rod TAC - 3/8 Bolt 13201-FT003
Bolt, Con Rod Replacement 13265-FT001
Pin, Wristpin Replacement 13251-FT003
CRANKSHAFT/BEARINGS
Crankshaft (Atlantic Series Special) 13401-FT001-A
Flywheel Bolt 90105-FT040
Crank Key 95161-10519
Crank Oil Plug 90344-FT008
Front Crank Pulley 13521-16010
Main Bearings Sold As Qty 1 = 2Shells Color
Crankshaft Main Bearings 1.980-1.984mm 11701-AE803-01 brown
Crankshaft Main Bearings 1.984-1.988mm 11701-AE803-02 green
Crankshaft Main Bearings 1.988-1.992mm 11701-AE803-03 yellow
Crankshaft Main Bearings 1.992-1.996mm 11701-AE803-04 blue
Crankshaft Main Bearings 1.996-2.000mm 11701-AE803-05 pink
Crankshaft Main Bearings 2.000-2.004mm 11701-AE803-06 purple
Crankshaft Main Bearings 2.004-2.008mm 11701-AE803-07 black
(-.010) Main Bearing 2.119-2.133mm 11701-FT001-14 blue
(-.010) Main Bearing 2.123-2.127mm 11701-FT001-15 pink
(-.010) Main Bearing 2.127-2.131mm 11701-FT001-16 purple
Crank Thrust Washer 11011-15010
Rod Bearings Sold As Qty 1=1 Shell Color
Connecting Rod Bearing 1.478-1.482mm 13281-FT004-01 brown
Connecting Rod Bearing 1.482-1.486mm 13281-FT004-02 green
Connecting Rod Bearing 1.486-1.490mm 13281-FT004-03 yellow
Connecting Rod Bearing 1.490-1.494mm 13281-FT004-04 blue
Connecting Rod Bearing 1.494-1.498mm 13281-FT004-05 pink
Connecting Rod Bearing 1.498-1.502mm 13281-FT004-06 red
Connecting Rod Bearing 1.502-1.506mm 13281-FT004-07 black
(-.010) Main Bearing 1.617-1.621mm 13281-FT001-14 pink
(-.010) Main Bearing 1.621-1.625mm 13281-FT001-15 red
(-.010) Main Bearing 1.625-1.629mm 13281-FT001-16 black
BLOCK/SEALS/WATER PUMP
Engine Block 11401-19386
Front Cover Assy 15120-16010
Front Crankshaft Oil Seal 90311-32001
Front Cover Gasket (Paper) 15197-FT001
Front Cover Gasket (Metal) 15197-15030
Rear Crank Oil Seal Housing 11381-15010
Rear Crank Main Seal 90311-70004
Rear Housing Gasket (Paper) 11383-FT001
Rear Housing Gasket (Metal) 11383-15010
Water Pump Assy 16100-19095
O-Ring Water Pump Mounting 96711-24035
Housing, Pump Inlet, Swift 16100-FT001
Gasket, Water Pump Housing 16124-15010
O-Ring Water Pump Housing Inlet 26967-FT010
Block Water Drain @#%$ 90910-09088
Oil Pressure Union 26975-09000
TIMING BELT/OIL SUMP/CAM COVER
Timing Belt 13568-FT001
Timing Belt Guide 13566-15010
Timing Belt Idler 13505-16021
Bolt, Idler Pulley 90109-10096
Pulley, Crankshaft Belt Drive 13521-16010
Cam Cover, Swift 008a 11201-FT001
Insert (TRD/Toyota), Cam Cover 90918-FT001
Dry Sump Oil Pan, Version I 12101-FT004
Windage Tray 12121-FT004
Dry Sump Oil Pan, Version II 12101-FT005
FUEL INJECTION
Fuel Pressure Regulator (008a) 23280-FT003
Fuel Pressure Regulator (014a) 23280-FT005
Injector Insulator (Rubber) 23295-FT001
Injector Hold Down Clamp 23297-FT001
M6x1.0x12 Allen Cap Screw 91300-FT024
M6 Flat Washer 90201-FT006
Fuel Rail 23807-FT001D
Fuel Rail Bushing 26942-FT005
M8 Fuel Rail Screw, Drilled 90105-FT035
Fiber Washer 26942-FT006
-6 Fuel Rail Fitting 96452-FT001
-6 O-Ring (Fuel Rail Fitting) 26967-FT009
Throttle Body (Cyl 1&2) (Bottom Injector) 22210-FT005
Throttle Body (Cyl 3&4) (Bottom Injector) 22210-FT008
Throttle Shaft 22211-FT002
Throttle Shaft Bearing 90363-FT003
Sync Fix Throttle Arm 21453-FT004
Sync Advance Throttle Arm 21453-FT005
Sync Advance Screw 90105-FT036
Sync Advance Screw Spring 26941-FT001
Sync Advance Screw O-Ring 26967-FT008
Sync Advance Screw Seat 13734-FT007
Sync Advance Pin 26933-FT002
Sync Advance Pin Spring 26941-FT002
Sync Advance Cotter Pin 90521-FT004
Throttle Shaft Nut 94181-FT011
Shaft Lock Washer 90201-FT013
Shaft Washer 90201-FT014
Butterfly 22209-FT001
Butterfly Screw 93219-FT002
M5x.8x20 Set Screw 90344-FT011
M5x.8 Nut 94181-FT010
Rubber Balance Tube 90447-FT001
Drive, TPS 22219-FT001D
M4x.7x16 Allen Cap Screw, Drilled (TPS) 90105-FT033
M4 Flat Washer (TPS) 90201-FT011
Velocity Stacks 1&3 22212-FT001A
Velocity Stacks 2&4 22212-FT001B
M6x1.0x20 Stud 91300-FT025
M6 Nylock Nut 94181-FT001
IGNITION PICK-UP ASSEMBLY
Magnetic Pick-Up Assembly 89711-FT003
Magnetic Pick-Up Bracket 15671-FT009
magnetic Pick-Up Spacer 90252-FT002
Shim Kit 15671-FT008
Screws, Magnetic Pick-Up 91300-FT027
Ignition Pick-Up Bracket Mount 15671-FT005
Trigger Wheel Adapter 13497-FT004
Trigger Wheel (36 Tooth) 13497-FT006
Trigger Wheel Screws 93219-FT004
M5x.8x16 Allen Head Screw (Bracket Mount) 90105-FT034
M5 Flat Washer (Bracket Mount) 90201-FT005
M8x1.25x55 Allen Head (Bracket Mount) 90105-FT009
M8 Flat Washer (Bracket Mount) 90201-FT007
M6x1.0x25 CSK Cap Screw (Bracket Mount) 93219-FT003
HARNERSS & ELECTRICAL
Chassis Harness Swift 008a 82112-FT005
Chassis Harness Swift 014a 82112-FT012
Fuel Tank Harness Swift 008a / 014a 82112-FT006
Gearbox Harness Swift 008a / 014a 82112-FT007
NLS Dash Control Switch & Harness
ECU Assembly Sequential / Dataloger - Bertils 19190-FT003-B
ECU Assembly Sequential / Dataloger - Comptech 19190-FT003-C
ECU Assembly Sequential / Dataloger - Hasselgren 19190-FT003-H
ECU Assembly Sequential / Dataloger - Loynings 19190-FT003-L
Cam Location Sensor 19300-FT002
O-Ring, Cam Location Sensor 26967-FT011
Coil Harness (Coil Over Plug) 82110-FT001
Ignition Coil (Coil Over Plug) 90919-02205
Engine Harness Swift 008a / 014a 82112-FT016
Water /Oil Temp Sensor 89422-FT001
Air Temp Sensor 89422-FT002
Ambient Air Pressure Sensor 89712-FT001
Throttle Position Sensor (TPS) 89452-FT001
Lambda Sensor 98400-FT001
Lambda Sensor Weldment 98400-FT002
PC Comm Link 82130-FT004
High Volume Fuel Pump Kit 23220-FT003
Fuel Injector (Hi-Flow, Green) 23209-FT002
Relay, Fuel Pump & Ign 85915-FT001
Relay, Fuel & Ignition 2002 spec. (Swift 014a) 85915-FT003
Gearshift Cut Switch, Tac 84110-FT001
Gearshift Cable & Mounting Kit, Tac 85000-FT001
holy crap! that would've taken me a week! at least now i've got a shopping list to give to my mechanic lol
Most of the part number on that list does not work, think it is USA only!
