Results 1 to 7 of 7
Thread: GZE cylinder block spec (standard diameters)
    omy
    Any one have a manaul they can check for me, all i could find is the na specs
    Sameul
    Bulleen
    100KW bottom ends are IDENTICAL to GZE bottom ends
    81mm bore
    The confirmation of this turned up as the first hit when I googled "4agze bore"
    Jul 2009
    problem solved.. all 4AGE's 20v 16v GZE have the same bore/stroke.. the 7A shares the same bore also.. (head gaskets are interchangeable)
    omy
    I know the bore, what I need to know is the fine details like, 81.01 - 81.03 so I can work out what rings and pistons I will need and to see how much the block has changed from stock (wear)
    Sameul
    Bulleen
    In that case, when you get the bore machined & honed, you ask them what oversize they took it out to and then order rings to suit
    Jul 2009
    you might need to mic up your bores then to get the figure yourself.. (using a micrometer)
    but if they didn't over bore it, and just gave it a hone.. you should be right with stock size rings..
  1. Standard gze in ae86
    By Sprintn in forum Technical - Questions
    Last Post: 19th November 2011, 03:19 PM
  2. WTB AE86 standard adjustable clutch master cylinder push rod
    By nIsMo86 in forum Cars or Parts Wanted
    Last Post: 6th June 2011, 11:04 AM
  3. FS: GZE Block
    By DR86FT in forum Car Parts For Sale
    Last Post: 27th November 2009, 05:51 PM
  4. 20v on a gze block
    By omy in forum Technical - Questions
    Last Post: 6th May 2006, 07:23 PM
