Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: slow gze
    Dusty
    Lynbrook
    hey guys as some of u may know i got my car tuned today anyway it only put out 75.2kw at 5622RPM and 102.6kpa@5622RPM M.A.P does this seem right mods include HKS FMIC, massive injectors (tuner said) umm lift pump with surge tank, 6kg flywheel, haltech e6a, sard exhaust with huge muffler with pea shooter silencer, ummm supposedly HKS cams too but im saying no to that soo what does everyone think???
    Mate got 150rwhp from a AE101 GZE with filter(getting hot air), trust front mount cooler and 2.5 inch exhaust.
    Senior Member ToySprinta's Avatar
    Steve
    Padstow
    thats pretty good for stck......
    My MAP GZE with bigport cams, p&p'd head, HKS pulley running 12psi, PWR cooler, Haltech E6X, Davies Craig water pump, Extractors and 2.5" mandrel bend exhaust and getting 120rwkw..........
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    Well the girlfriends AE92 GTZ gets 102 kw at the wheels, thats MAP with a cat back exh everthing else stock!
    Apr 2011
    Steve
    102kpa means it is not making any boost, for a stock engine the number should be up around 175kpa, The tuner should have known that!
    Sprinter Veteran
    Poh
    Bevo
    i got 114.5hp with pod filter, ems ecu thats about it and the car was overheating on the way there with a broken thermostat too
    That depends if it is 102kPa absolute or 102kPa boost.
    If absolute then yes, no boost at all, and so that means the power figure is impressive for a low comp 4AGE.
    If boost then you must have a big pulley on there and the power output is lamentable.
    Dusty
    Lynbrook
    he said it doesnt seem to be runnning much boost.... but on the boost gauge it is saying 0.5bar if that helps
    Senior Member DavisJD's Avatar
    somethings is deffinetly not right there, should be making alot more power, should be making somewhere from about 110-130rwkw
    Id get him to look over it again, and if not take it to another mechanic that knows what he's doing!!
    Dusty
    Lynbrook
    i took it to a place that specialises in haltechs but is mainly a v8 specialist too so any one know a good tuner 4 gzes in melb???
  1. Replies: 5
    Last Post: 13th September 2012, 08:13 PM
  2. Jaymans SLOW buildup
    By Jayman in forum KE70 / AE71 Owners Forums
    Last Post: 25th October 2010, 02:02 PM
  3. super slow mo
    By breno in forum Offtopic Discussions
    Last Post: 15th October 2009, 11:25 PM
  4. Ultra Slow
    By sherlock in forum Offtopic Discussions
    Last Post: 22nd March 2008, 07:25 PM
