Results 1 to 8 of 8
Thread: turbo oil feed
    hey, does anyone have any info on where to take the oil feed for a turbo on a 4agte?
    also where do most people run the water pipes for cooling the turbo?
    its for a t25/t28
    omy
    The one that has oil press...........
    so, what you are saying is most people just put a 't' peice in the oil pressure switch hole and run it from there?
    Greg
    Coorparoo
    that is correct, the return from the turbo just gets plumbed into the sump
    Apr 2006
    hmmm talkin about oil feed how small is the resriction on a t28 bb
    omy
    Look on top of the turbo, there is one in there for factory.
    what about water pipes? do most people just leave them disconneted or something?
    Eddie
    Don't just leave the water pipes disconnected! There's many many different ways you can do it. Probably one of the easy/cheaps ways is to T off your heater hoses to get a water feed for them. Or you can setup a direct feed from the radiator.
    Eddie.
  1. 4AGE Turbo sump oil drain pictures
    By R&D Mechanical in forum Technical - Questions
    Last Post: 30th May 2012, 05:42 PM
  2. Feed the mothaf*ka
    By hachi_dk in forum Offtopic Discussions
    Last Post: 9th June 2010, 07:33 PM
  3. side feed injectors
    By Jonny Rochester in forum Technical - Questions
    Last Post: 10th June 2008, 06:49 PM
  4. turbo water and oil plumbing
    By slidn_ways in forum Technical - Questions
    Last Post: 30th May 2008, 07:56 PM
  5. oil feed for 4agte?
    By cr86zy boy in forum Technical - Questions
    Last Post: 11th March 2007, 10:36 PM
