Results 1 to 10 of 16
Thread: earthing kits????
    Oldschool Member
    May 2005
    jus wondering about the earthing kits u can buy that give u a better ground earth and better spark etc etc.I havnt heard much about them though or if they are benefitial to use, ive seen a few on some members engines on here.If u are using one or have used on can u tell me about them and if there worth running.
    ......ur info will much appreciated thank you.>>-Dave
    They are only a benefit if you are having grounding problems. Basically all they do is get a good connection from your block and other electrical devices back to the negative terminal of the battery.
    You do it yourself if you are having problems by running heavy gauge cable between the important points (mainly block, ignitors, headlights and ECU earth) and the battery.
    Veteran slydar's Avatar
    Dimitri
    they sorta make sense on old cars like 86's. because the factory earths are usually a little worse for wear (corosion/broken wires/strands/just been left out in engine conversions ect).
    but you can achieve the same effect by servicing/replacing your stock earths. and its neater.
    its actually been tested in some japanese mag back to back. earth kit v's servicing/replacing your stock earths. same results.
    my 86 has an earth kit, i just left it on cos it came that way from japan and gives it that jap feel (to look at).
    to sum up. earth kits are pretty ricey.
    78's
    Jul 2009
    as my battery is in the boot, i just made sure that the neg has a nice fat earth cable, and just for good mesure, got some 8G amp wire and ran it to 3 other spots in the boot, like chassis rail, floor, back of backseat/parcel tray bottom.. then ran 1 or 2 extra to my head/block from the chassis at the front..
    i was actually having dramas with the starter not earthing right.. so i connected it to the chassis seemed to work after that.. although the engine did have an earth, maybe it wasn't good enough? or covered in paint...
    Jarrod
    Magill
    i put heaps of earth packs on cars at work with leads it is supposed 2 give a 5kw increase atw. plus we found out it makes the car sterio reception work alot further away than normal.
    if u look at most cars comimg in2 aus from japan they earth everything. i saw this one car with like 10 wires comin off the engine.
    Justin
    get an electric supercharger and an earth kit on a 4age and 4agzes will be flat out keeping up
    I started the ball rolling...
    Not member #1 anymore
    Justin
    i just made a new earth with a single 4gauge wire from the battery and a 4gauge to the starter motor cause the original toyota ones were poor and freyed
    Nick
    Qld
    Brisbane south
    Aus
    earth kits are good but buying one is gay
    how hard is it to lug & fix a wire at 2 points
    Paul
    Gold Coast
    My front cut came with one when I bought it. I only put it on cause it looks fuken cool!
    Oldschool Member
    May 2005
    thanx for input,
    i guess there really not a "must have" when u can just change ur originals with new ones and add a few more.
  1. Jdm Ae86 Ultra Leads Earthing Kit
    Last Post: 3rd March 2012, 11:12 AM
  2. FS: Full coil over for AE86/KE70, Aftermarket 4AGE ECU, Earthing kit
    By charlie_keto in forum Car Parts For Sale
    Last Post: 6th July 2010, 07:47 PM
  3. 16v earthing
    By Tim.duncan in forum Technical - Questions
    Last Post: 29th July 2009, 11:41 PM
  4. earthing points on a ke70
    Last Post: 18th May 2009, 09:26 PM
  5. are 4a clutch kits the same as 4age kits
    By kali_man_tan in forum Technical - Questions
    Last Post: 24th July 2007, 11:09 PM
