Results 1 to 10 of 10
Thread: AE86 4age idle speed to hight
    Oldschool Member
    Apr 2006
    Hi, i have a problem with my idle speed... Its running about 1600, and with the light on about 1400 rmp... Any typical problems?
    Mvh Jack Frandsen(denmark)
    Veteran slydar's Avatar
    Dimitri
    vacumm leak. timing too advanced. combination of both.
    78's
    Oldschool Member
    Apr 2006
    Oki, any typical vacumm leak's?
    Jul 2009
    booster line could be cracked.. i don't think a 3mm vac hose would make it jump that much.. check your timing.. but there are also a few 3mm lines off the inlet manifold and throttle body.. check them.. or even just replace them.. does it make a loud hissing noise on idle? has it just all of a sudden started doing this?
    Oldschool Member
    Apr 2006
    I've just cheked the timing, it was fine. Ang i have replaced all the vacum hose's... You wrote "but there are also a few 3mm lines off the inlet manifold and throttle body" Sorry but i really dont understand that sentence :-( Sure i know what manifold and throttle body means, but not what you mean "with lines off the ..." Is it like fittings? Were the hoses get stock to?
    Jack(denmark)
    Jul 2009
    there are a few small 3mm steel pipes at the top of the throttle body.. check those vac hoses..
    also it could be your cold start wax pellate thing.. you know the 2 water lines that go to the throttle body..that controls to a degree your cold start idle speed..
    it your car fitted with pwr steering?
    Oldschool Member
    Apr 2006
    Ok, i will check the pipes tomorrow. I will look at the cold start thing(if i can find it) :-) No pwr steering...(no ae86 with pwr steering in dk)
    Better get to bed, its midnight in denmark right now :-)
    Jack(dk)
    Jul 2009
    the wax pellat thing i would be inclined to remove.. here is aussie in the cold est of cold (queensland at least) rarly dips below 0... so i don't even run a cold start injector! if you have another throttle body try changing them over..
    Oldschool Member
    Apr 2006
    Yes i tried to hold my finger over the hole whitch leads air under the gas throttle, then the idle speed falls... So this may be the problem...
    Jul 2009
    alrighty then! try blanking it off for a while using one of those little platsic/rubber nipples from a auto parts store.. there 4-5mm i think
  1. URGENT!! 1JZGTE idle speed valve
    By dr1ft-pig in forum Cars or Parts Wanted
    Last Post: 22nd October 2009, 08:20 AM
  2. Carby Idle speed screw?
    By grape_moosha in forum Technical - Questions
    Last Post: 14th December 2007, 10:38 PM
  3. What does a 4age idle at
    By deanoo in forum Technical - Questions
    Last Post: 6th December 2006, 08:03 AM
  4. Idle speed.
    By spranga in forum Technical - Questions
    Last Post: 2nd May 2006, 02:25 AM
