booster line could be cracked.. i don't think a 3mm vac hose would make it jump that much.. check your timing.. but there are also a few 3mm lines off the inlet manifold and throttle body.. check them.. or even just replace them.. does it make a loud hissing noise on idle? has it just all of a sudden started doing this?
