there are a few small 3mm steel pipes at the top of the throttle body.. check those vac hoses..
also it could be your cold start wax pellate thing.. you know the 2 water lines that go to the throttle body..that controls to a degree your cold start idle speed..
it your car fitted with pwr steering?
