when will this be competing?
sounds like it will be a bit of a datto burner
Now before any one starts to stick it to me no names mentioned (improvedae86) I am simply posting my car up on this site because I am a fellow AE86 nut, and I am now a site sponsor and many of the parts I sell are featured on the car, so please I dont want a repeat of the NS thread here.
That said, what of the car?
Based on the car that made it all famous in the beginning the Toyota AE86, we have taken a good clean Australian delivered car and are in the process of transforming it into what we hope will be the ultimate drift car in Australia.
Just a few specs on the car so far:
Engine & Drive line: ST205 3SGTE, 325rwkw (approx 600 fly wheel HP), Fully ballanced, Eagle H Rods, Ross Racing Pistons, Total seal Rings, Cometic HP Head Gasket, ARP Stud Kit, Stellite Valves, Waggot Custom Grind Cams, HKS Cam Wheels, SARD Fuel Rail, 4 x 1500cc injectors, Raceflo Plenum, Raceflo Turbo Manifold, GT35/40 Turbo, Turbo Smart 50mm Pro Gate, Turbo Smart Blow off, Turbo Smart Fuel Reg, Turbo Smart E Boost Controller, Microtech LT10 Computer, Exedy Race Clutch, Tremec TKO-2 Gearbox with Albins Gear set, Toyota Hilux full spool Diff.
Body Misc: Carbon Bonnet, Dash, CBY body kit & flares, AGX adjustable struts, Ebachi Springs and coil overs, T3 5 link adjustable rear, T3 fully adjustable front end, Willwood 4 spot calipers and 310mm x 32mm rotors, R32 GTR Skyline rear calipers and rotors, 10 point cage, 17 x 9 front wheels with 215 x 30x17, Rears 18 x 12, 295 x 30 x 18, alloy drop tank, twin bosch motorsport pumps, Velo Race seats, Sparco Steering wheel, PWR Radiator, plus much more
is it coming to Qld John?
Are you still having problems with breakign gearboxs or is that a thing of the past with the tremac?
Looks & is tuff as man best of luck with it
Thank you Sir![]()
The tremec is the new box, W58's were the old box, and yes we did have a few issues, like breaking input shafts, striping 1st gear, 3rd gear and 4th gear, oh and all in less than 3 hours running time, but the tremec will fix all that.
Jon
I hope so, why's that are you offering to drive it?
Could you plz add some still pics of your machine
would b grateful
chris
