Results 1 to 10 of 15
Thread: 4ac n timing belt
    hi does any1 know for sure whether the 4ac is an interference or non-interference design?..that is if the timing belt snaps will it damage the valves etc.?...and any1 knows how often i should replace the belt?60000Km or 100000 km?
    Greg
    Coorparoo
    im 90% sure they're non-interferance.
    as with i'm fairly sure ALL toyota timing belt motors (at least the ones i know (not the new ones)) are all non-interferance
    any1 else wanna share their knowledge/experience? plss?
    Senior Member Dori_Dori's Avatar
    Andy
    Westside
    im pretty sure you change them every 100 000km
    dats what i do.
    i hope this helps
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Yeah they are definately a non interferance design.
    (I bought a AE82 with a broken belt, changed it and it went no worries)
    I'm pretty sure they are specified as a 60,000 belt but will
    go to 100,000 without dramas
    ah ic..dats cool then..thx alot..btw did u change it yourself?
    Senior Member Medicine_Man's Avatar
    Justin
    North
    My brothers old AE71 had a broken timing belt when we bought it, Didn't take too long to replace. Quite an easy job to do yourself if you have some mechanical ability.
    Why hesitate when you can accelerate???
    Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
    4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
    Jan 2006
    change every 100,000 and year i had mine break at 2am when i was drunk and changed it the next day and it was fine
    Jul 2009
    get engine to TDC
    undo crank bolt
    pully off
    plastic covers off
    undo the 10mm bolt on the tensioner
    hold tensioner to the side
    take belt off..
    at this point you can change the cam seal (recommended)
    and the tensioner (if you buy a timing belt kit you get one with it, and a cam seal)
    put the new belt on, making sure the marks at the top of the cam gear and cover are lined up, and the key on the top of the crank is at the top still..
    do up the tensioner so the belt is tight.. not insanely tight.. just nice and firm..
    covers on.
    pully on..
    away you go
    thx guys..yea i did a google search how to replace it ..anyway..i got the other belts on as well...the fan n aircon belt..so gotta take those off before i can start taking the crank pulley out...btw when u undo the crank bolt, will it turn the engine as well?..coz to get to the TDC u turn the crank bolt clockwise?..
  1. WTB: SA: 4ac timing belt cover/shroud
    By remrusty in forum Cars or Parts Wanted
    Last Post: 4th September 2012, 08:11 PM
  2. timing belt belt tension bolt socket?
    By Tim.duncan in forum Tool Talk
    Last Post: 19th January 2010, 01:17 PM
  3. 16v timing belt and aircon belt
    By ae86 in forum Technical - Questions
    Last Post: 12th November 2009, 01:51 AM
  4. Timing belt change on 4ac
    By dreny in forum Technical - Questions
    Last Post: 3rd April 2008, 02:47 AM
  5. 4ac timing belt
    By Ade_Mc in forum Technical - Questions
    Last Post: 19th February 2008, 01:16 PM
