Results 1 to 6 of 6
Thread: 20V Rear crank seal yer?
    Senior Member SPEEDCORE's Avatar
    Thought I had a leaking clutch slave and then noticed that there was oil coming from the clutch cover and the clutch fork little window thingy ..... it had worked its way onto the slave....
    I'm dealing with a crank seal or a front G/B seal yeah?
    So.... need to know if the rear crank seal on a B/T 20V is the same as a 16V?
    Unfortunately I am also unable to fix this at home.... so what would be the rough price of getting this done?
    Cheers,
    Adrian.
    Terry
    Ipswich
    same rear crank seal 16 & 20V, contact me at work if you are interested in getting it fixed professionally.
    Elite rthy's Avatar
    Leo
    Tulla
    It is the rear crank seal but luckily rear crank seals are manageable to change and the part price of them is cheap.
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    they arent that hard to change, i did change mine when the engine was out. however, engine in would be another issue...
    would definately be alot easier if the car on a hoist, so yea give terryo a yell
    Jason
    Gold Coast
    had the same prob with my 20v,
    pulled the gearbox off one weekend and changed the input shaft seal on my gearbox, only to put it all back together and find it still leaking,
    So weekend after pulled it all apart again and changed rear crank seal, (all in my garage using a normal jack and axle stands)
    moral of the story, change every seal in sight while you have the thing apart, saves hassles down the track.
    Jason
    Gold Coast
    oh and your clutch disk has prob had a good soaking of oil and will need to be changed.
  1. rear main seal
    By sic86 in forum Cars or Parts Wanted
    Last Post: 13th October 2009, 01:17 AM
  2. Replacing front main oil seal (crank oil seal) 4ac.
    By dreny... in forum Technical - Questions
    Last Post: 18th June 2009, 03:21 PM
  3. 20v Crank VS. 4AGZE Crank
    By starni_boy in forum Technical - Questions
    Last Post: 28th June 2008, 09:09 PM
  4. T50 rear oil seal
    By Tom86 in forum Technical - Questions
    Last Post: 17th March 2008, 12:28 AM
  5. WTB: Rear window seal
    By 70XIN in forum Cars or Parts Wanted
    Last Post: 19th August 2007, 12:58 PM
